Notices
Old 04-19-2008, 12:52 PM   #1
Test m2-atx
I'm trying to figure out what isn't working, my M2-ATX or my motherboard.
I have a multi-meter that I really don't know how to use but it looks as if I'm getting battery power to the M2 as well as keyed power.
Where can I test the output? I tried the 5v hd power and got nada. I'm not sure if a burnt motherboard would effect that though.
Tanky.
Darren
Dramey is offline   Reply With Quote
Old 04-19-2008, 08:10 PM   #2
pRoFiT's Avatar
So i would wait to see if anyone else agrees with this...I would connect Power(RED) and ACC(white) to the m2atx and then ground the green wire on the 20 pin harness. That is power good and tells the power supply that the motherboard wants or needs to turn on. Then you can check 5 and 12volts from the 4 pin Hard drive power connector. red is 5 and yellow is 12 in respect to the black ground pins. Make sure you are in DC and not AC on your multi-meter.
On standard computer power supplies you can plug the 120vac from your house and then short the green wire to ground to make the power supply turn on. I would think that the m2atx would do the same thing. I have one and would check but its burried in my carputer right now.
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
pRoFiT is offline   Reply With Quote
Engine Noise with M2 ATX lucky1 Power Supplies 33 03-03-2008 09:54 PM
m2 atx questions.. ludikris Power Supplies 4 10-03-2007 06:51 PM
Wtb :: M2 Atx Dc/dc Psu !!! CoupeE46 Classified Archive 0 01-28-2007 04:06 PM
Problem m2 atx and 3.5" hard drive Mitski's Rider Power Supplies 2 10-05-2006 12:52 PM
morex 80wpsu and reg ATX cable dilema!! surfy Power Supplies 1 08-16-2005 09:06 PM
