Notices
Old 04-20-2008, 02:35 AM   #1
High Current USB
I would like to put a WD Passport in my glovebox that I can easily bring into the house or work when I do file maintenance. It is drawing over 500ma and giving me a blinking error light and not powering up. (WD lists 1A draw on their spec sheet.) It works fine on my other computers. What is a simple, inexpensive way for me to add a safe +5v 1A USB port off my 12vdc BATT that can boost the power? Was thinking something like a diode or regulator, but not sure if they would be safe enough for the HDD.
jayhawkclint is offline   Reply With Quote
Old 04-20-2008, 02:52 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
if your PSU has 1A @ 5v available, the easiest is to splice the wire from the HD, so it disconnects the power and route the 5v line direct from the PSU.
2k1Toaster is online now   Reply With Quote
Old 04-20-2008, 03:00 AM   #3
Not really an option at this time. Really hoping to run something off the dash +12vdc.
Old 04-20-2008, 03:09 AM   #4
2k1Toaster's Avatar
Then there are simple things like http://store.mp3car.com/Point_Of_Loa...plies_s/10.htm
the DCL11
Old 04-22-2008, 06:56 PM   #5
USB ports on occasion will chop off power if above 500ma is being drawn, to get around this, there are cables made A to MiniB which have a passthrough usb attached to the cable to draw power through another port without blocking it. Dunno if you have a port to spare but it may be worth a shot. Wouldn't know where to get one tho... On the other hand there is the POL (point of load) route as mentioned by Toaster which converts the 12v to 5v which you just splice into your usb.
My opinion, get a powered hub which doesn't limit the load, or a not so fancy enclosure.
That being said, EVERYTHING gives you cancer nowadays so live it up before your cornflakes give you malignant tumors.
Furian is offline   Reply With Quote
Thinkpad usb related issue maybe trash computer? bimmerpc Laptops, Tablets, UPMCs, etc. 2 10-19-2007 12:41 PM
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 12:49 PM
Via Epia Mii10000 USB buurin General Hardware Discussion 19 07-22-2006 03:52 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
