USB ports on occasion will chop off power if above 500ma is being drawn, to get around this, there are cables made A to MiniB which have a passthrough usb attached to the cable to draw power through another port without blocking it. Dunno if you have a port to spare but it may be worth a shot. Wouldn't know where to get one tho... On the other hand there is the POL (point of load) route as mentioned by Toaster which converts the 12v to 5v which you just splice into your usb.
My opinion, get a powered hub which doesn't limit the load, or a not so fancy enclosure.
That being said, EVERYTHING gives you cancer nowadays so live it up before your cornflakes give you malignant tumors.
