Notices
Old 04-22-2008, 05:18 PM   #1
Remote turn on
Hi, im new to posting on this forum but have been lurking for a few years now waiting to get a decent car worth putting a PC in. I have 1 question before i install every thing. can i use the head unit remote to turn my pc on instead of a switching ignition feed? saves running another cable to the rear
thanks
narayan is offline   Reply With Quote
Old 04-22-2008, 07:17 PM   #2
Depends if your head unit has an aux, ret, or other switched power output in the rear. Many do, many don't. Personally, I built my own switch because I really don't like the idea of the pc coming on and off when I so much as go 5 minutes to the grocery store.
Simple switch:
Cat5 cable leads from power and led headers on mb to front of vehicle
Cat5 receiver splits cable into wires
small plastic box, red push button, 2 leds, makes switch for 5$ from radioshack
power on, power off,
Especially if you are not replacing the head unit, I find this to be quite easy.
You would also need to have more of a plan because whether you are using an inverter or a dc-dc psu and several other things factor into this.
good luck
That being said, EVERYTHING gives you cancer nowadays so live it up before your cornflakes give you malignant tumors.
Furian is offline   Reply With Quote
Old 04-22-2008, 11:00 PM   #3
FusionFanatic's Avatar
the HU's REM output is a simple 12vdc switched output, just like your car's ACC or IGN circuits. so yes, you can use it in place of the car's ACC/IGN circuits.
just like your car's ACC or IGN circuits, you can use the 'REM' line as a signal wire to turn the PSU on or to control a relay (to cut power to the PSU when the car is off).
FusionFanatic is offline   Reply With Quote
FS/FT: OEM Fog lights, Cear corners, Alarm system, Bumper, OEM turn signals BIzFlawless Classified Archive 2 02-20-2007 11:21 PM
Can I use a Remote Turn On from Head UNit to power Motherboard? whosyourdady08 General Hardware Discussion 2 12-12-2005 09:44 AM
Can I use a Remote Turn On from Head UNit to power Motherboard? whosyourdady08 General MP3Car Discussion 6 12-11-2005 09:18 PM
remote turn on lead from headunit to power up PC BluCivic93 General Hardware Discussion 3 07-27-2000 03:13 PM
