The MP3car.com Store
Thread Tools Display Modes
Old 04-23-2008, 04:04 PM   #1
HiJackZX1's CarPC Specs
HiJackZX1's Avatar
Vehicle: 03 Dodge Durango SLT
My Photos: (162)
OPUS 320 and KINO-690S1
I finally got my system together, but my OPUS 320 will not shut down or powerup when it gets power on the ACC 12v+ line. I read that BIOS has to support ACPI 2.0 to work with Opus 320W. Its funny that this MoBo has so many features but does not have ACPI 2.0, only ACPI 1.0. Does this mean I cannot use the power supply? It does work with the push button on the PC, but not through the OPUS ignition feature.
Here are my PC stats, i have a M2-ATX, and can put that in, but i do not know if it is powerful enough. Can someone give me a wattage estimate.
1. KINO-690S1 MoBo, with X1200 series GPU
2. AMD Turion X2 64 bit TL-56 processor
3. Two 7 port USB hubs, via the 5V rail
4. XM Direct
5. Toshiba 2.5 40GB HDD
6. IDE to SATA converter for HDD (5V rail)
7. DVD Rom
8. IDE to SATA converter for DVD (5V rail)
Everything else in my massive setup is powered up via relay since it all is fused and have their own regulators. Do you think a M2-ATX can handle this. If not is there a way to upgrade my ACPI from 1 to 2?
PLANNING [IIIIIIIIIIIII] DONE
ITEMS [IIIIIIIIIIIII] DONE
INSTALL [IIIIIIII---]
BUDGET [IIIIIIIIIIIIIIII]IIIIIIIIIIIIII
HiJackZX1 is offline   Reply With Quote
Sponsored Links
Old 04-23-2008, 06:04 PM   #2
The1Architect's CarPC Specs
The1Architect's Avatar
Vehicle: 2003 Honda Accord Coupe EX V6
My Photos: (23)
I have the same problem but mine DOES turn off if i cut the feed off the ACC wire but won't restart if ACC is again fed...
i thought of a relay option but i guess if i do that i will lose the hibration option!!
>> > Design & Planning . . . . . . . . . . . . . . . . . . . . 100%
> Software Installation . . . . . . . . . . . . . . . . . . . 95%
> Hardware Installation . . . . . . 30%
>>> Overall Progress . . . . . . . . . . . . . . 75%
The1Architect is offline   Reply With Quote
Old 04-23-2008, 06:17 PM   #3
HiJackZX1's Avatar
My Photos: (162)
I guess it does not have acpi 2 or atx like mine.... I may try the M2-ATX.... I emailed OPUS lets see what they say.
Old 04-23-2008, 06:19 PM   #4
HiJackZX1's Avatar
My Photos: (162)
Here is the response from them.
Hi,
Please check the two wire power-switch cable for proper connections to On/Off pin on main board (Polarityof this cable:Green is positive, White is negative).
In BIOS,
Set restore on AC power loss OFF
Set ACPI to 2.0
Set soft off by power button INSTANT OFF
If it still does not work, can you tell me how many blinks the PS indicate and the duration of the blink?
Thank you.
Tech. Support
Thong Tran
Opus Solutions Inc.
9610 Research Dr.
Irvine CA, 92618
(949)387-1010 ext.225
Old 04-23-2008, 11:37 PM   #5
My Photos: (23)
So if my motherboard doesn't have ACPI 2.0 does that mean that I can't use the auto on/off feature?
Old 04-24-2008, 12:00 AM   #6
HiJackZX1's Avatar
My Photos: (162)
I sent them a second email, they havent said yet that you cant, but its starting to look that way. I have my M@-ATX on standy... I may have to buy the M4-ATX.
Old 04-24-2008, 09:42 AM   #7
My Photos: (23)
last night i tried again and it did power on once but not again.
shutdow work perfectly though
Old 04-24-2008, 12:05 PM   #8
My Photos: (23)
ok so it turns out that i have the right equipment with the right BIOS settings except that i needed the change the startup voltage jumper from 12.5 to 11V (from pin 5 to 4) since am testing with the ATX PSU rather than using the car battery.
now working like a charm
Old 04-26-2008, 09:18 PM   #9
HiJackZX1's Avatar
My Photos: (162)
Turns out I did too. I changed to PIN 4 also and it worked perfectly. So once we put it back in the car, we switch it to PIN 5?
Only issue I have now is that I have a shut down delay, but the lowest is 10 seconds.
Old 04-30-2008, 11:00 AM   #10
My Photos: (23)
yeah i don't want that shutdown delay as well .. i was wondering if we can use Remote 2 wire for more than one device since remote 2 doesn't have a delay
Sponsored Links
Old 04-30-2008, 01:53 PM   #11
HiJackZX1's Avatar
My Photos: (162)
I actually do not have anything on the remote wire. Only thing I did have were the amps, but i would get that nasty pop sound, so now i have the remote wire for the amps connected to com port 3 and a software detects when the soundcard becomes active and then turns on the amps.
Old 05-07-2008, 11:43 AM   #12
coffeejolts's CarPC Specs
coffeejolts's Avatar
Vehicle: 2005 Mazda6
My Photos: (0)
Why would you not want the ten second shutdown delay? I find that it is a very practical feature, and ten seconds isn't going to drain your battery.
My CarPC page
coffeejolts is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
