The MP3car.com Store
Thread Tools Display Modes
Old 04-30-2008, 04:09 AM   #16
Fox_Mulder's CarPC Specs
Fox_Mulder's Avatar
Vehicle: 2004 MR2 Spyder TTR
My Photos: (49)
J5 can be used to reprogram the pic using a method called "In Circuit Serial Programming" if we had access to the firmware, all that is required is a simple circuit hooked up to an rs232 port in order to reprogram the pic.
I can verify that my micro atx motherboard is not ignoring the off pulse, because the off pulse is only sent after 1 minute, and then after 1 minute from that does it go into HARDOFF.
edit: I might take this m4 into uni and use the scopes there, but I dont think I'll learn anything new.
Fox Mulder
2001 Toyota Avalon Vxi
Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353
Fox_Mulder is offline   Reply With Quote
Sponsored Links
Old 05-01-2008, 09:10 PM   #17
My Photos: (0)
I received mine, that I bought off ebay and suffered from the same problem as the OP but one of the setting was different the off delay was 5sec and then 1 min for Hard off, the rest was 1min for offdelay and then 1min for hard off,
I'm sending it back and I'll buy one from mini-box unless anyone can confirm that the store here has the new firmware
a2carat is offline   Reply With Quote
Old 05-02-2008, 08:44 AM   #18
hailrazer's CarPC Specs
hailrazer's Avatar
Vehicle: 2007 Gmc Yukon Xl
My Photos: (0)
The mini-box rep told me this on Wednesday:
Quote:
It is a firmware bug we fixed ~1 week ago, but it affects your behavior only for the first ON/OFF cycle.
Please see attached manual with the new timing tables and please read about the "AutoLatch" feature.
I will ask MP3car.com to send back all the units so that we will reflash them... Luckly the damage is not that big, only a limited number units were sent out so far...
-Andrei
So the ones in the Mp3car store probably won't have the new firmware for a few weeks I would imagine.
My 2007 Yukon XL setup. http://www.mp3car.com/vbulletin/show...64-5000-a.html
hailrazer is offline   Reply With Quote
Old 05-02-2008, 10:13 AM   #19
jimmler's CarPC Specs
jimmler's Avatar
Vehicle: 1991 Mitsubishi Montero
My Photos: (0)
They did update their manual on the website and a copy of this changelog:
03/03/2008 Initial Release, Firmware release 1.0
04/15/2008 Removed C53 (adjustment to the 5V rail rise time)
04/15/2008 Firmware 1.1 changed timing scheme as follows:
P0 STANDARD PSU
P1 5sec / 1min was 5sec 1 min
P2 5sec / NEVER was 5sec / 1 hour
p3 1min / 1min was 5 sec / NEVER
p4 15 min / 1 min was 30 sec / 1 hour
p5 15 min / NEVER was 30sec / NEVER
p6 30 min / 1 min was 30min / NEVER
p7 2 h / 1 NEVER was 3h / NEVER
04/14/2008 Firmware 1.1: 1minute Ignition latch was active only when M4-ATX was powered on for the first time.
04/14/2008 Firmware 1.1: Further alignment in the way 12, 5, and 3.3V rails startup timing
04/14/2008 Firmware 1.1: Firmware version can be viewed via USB HID link.
Unfortunately there's still no information on the USB interface other than the last line of the change log.
I bought mine from short-circuit.com. I wonder if they will allow me to return it for an updated unit. Hailrazer, since you have a better rapport with mini-box than I do(they have NEVER responded to any of my e-mails), can you find out from Andrei if they are replacing all units or only the ones sold to mp3car? Thanks!
-Jim
Nipomo, CA
jimmler is offline   Reply With Quote
Old 05-02-2008, 10:19 AM   #20
hailrazer's Avatar
My Photos: (0)
Just fired off an email, I will let you know what they say.
Sponsored Links
Old 05-03-2008, 06:06 AM   #21
hailrazer's Avatar
My Photos: (0)
Here's the reply :
Quote:
In general, they should ask the reseller for a firmware upgrade and the units will quickly get replaced, but we won't say no if they contact us driectly...
Luckily we did not sell too many units with the 'old' firmware....
-Andrei
Old 05-08-2008, 12:50 PM   #22
hailrazer's Avatar
My Photos: (0)
I just got my new M4-ATX power supply from mini-box installed.
And I am happy to say it works perfectly. Goes into hibernate in 5 seconds and the screen turns off
Everyone should try to get one with the new firmware. Mini-box is good to work with once you get them answering emails )
Old 05-08-2008, 12:54 PM   #23
My Photos: (0)
Mine is due to arrive tomorrow.
I will let you know if it works.
PS, how did you get yours before me? >_<
ArcaneDreams is offline   Reply With Quote
Old 05-08-2008, 12:55 PM   #24
hailrazer's Avatar
My Photos: (0)
I Bit$%ed harder and more
Old 05-08-2008, 04:07 PM   #25
GhostRiderDad's CarPC Specs
GhostRiderDad's Avatar
My Photos: (4)
Is there a way to upgrade the firmware of the M4-ATX without returning it? Like updating the bios? I don't know if mine has the above mentioned problems yet because I have not bench tested it yet. What are your methods for bench testing? I got mine on ebay from short-circut in April. I trimmed some of the plastic off the terminal black so that the PS would fit in an old Dell PS case, so I don't know if they would return it or not.
GhostRiderDad is offline   Reply With Quote
Old 05-08-2008, 09:03 PM   #26
Fox_Mulder's Avatar
My Photos: (49)
They emailed me the new firmware (I am in Australia, I dont really want to have to wait for a new unit lol). You need an "In Circuit Serial Programmer" to program the 18F2450 PIC microcontroller. You can build this programmer there are a few schematics on the internet.
Fox Mulder
2004 Toyota MR2
Old 05-09-2008, 12:05 AM   #27
My Photos: (0)
did you connect and fix it?
Old 05-09-2008, 12:16 AM   #28
Fox_Mulder's Avatar
My Photos: (49)
Havent had a chance yet, too many assignments with uni I will give it a try this weekend.
Fox Mulder
2004 Toyota MR2
Old 05-09-2008, 01:34 AM   #29
My Photos: (0)
We were finished for the semester last week. Shouldn't you be done soon?
Old 05-09-2008, 01:38 AM   #30
Fox_Mulder's Avatar
My Photos: (49)
We still have lectures, June 13th is the last day of my exams.
Fox Mulder
2004 Toyota MR2
Sponsored Links
vB code is On
Trackbacks are Off
Pc Mini fungke General Hardware Discussion 7 06-02-2005 04:43 PM
Bug Tracking (sorry long but please read) liquid_smoke Software & Software Development 23 04-22-2005 03:12 PM
Check this Mini Box M100 heartpumper General Hardware Discussion 1 08-31-2004 11:29 AM
EPIA VIA M10000 Mini ITX in a 6x9 Speaker Box pic. 2 hour build time. LESLIEx317537 General Hardware Discussion 23 02-13-2004 12:24 PM
mini box for carputer idea? *DaNut* Newbie 1 10-13-2003 09:40 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
