Quote: Originally Posted by
fischb22
a) is the red led on the DSATX flashing? if so how many times?
b) have you checked with a multi-meter your ACC, VIN+, and ground connections on the DSATX?
c) have you tried reversing the motherboard header pin?
a) the LED on the DSATX does not turn on at all and does not blink
b) Yes, VIN gives a constant 12.X volts. ACC cycles from 0 to 12V when turned on, and ground shows continuity between the wire and the car chassis.
c) Yes, I had a similar problem in the previous installment of my computer and recognize the symptoms where the computer turns on for a couple of seconds and then restarts. This was the first thing I attempted to switch accept this time I didn't have any success.
