Notices
Old 05-10-2008, 02:30 PM   #16
hailrazer's Avatar
Did you check the fuse on the M4-Atx board?
My 2007 Yukon XL setup. http://www.mp3car.com/vbulletin/show...64-5000-a.html
hailrazer is offline   Reply With Quote
Old 05-10-2008, 02:33 PM   #17
yup! all my fuses including the one on the M4 everything is good no broken links
racer_X is offline   Reply With Quote
Old 05-28-2008, 01:09 PM   #18
Quote: Originally Posted by Fox_Mulder View Post
I have been communicating with Laci from mini-box: tlaci AT mini-box.com
As have I. I have the software in-hand and I wired up the cable with the ORIGINAL spec last night and it worked, but today it did not even recognize the device. I don't understand why it would recognize it once, and actually work to change some parameters...but not even recognize it today.
I suppose I will rewire it. Ugh.
So do I wire both pins 1&2 to the black ground of the USB cable?
*EDIT*
I did have it wired up correctly (2nd version). The numbers were just labeled different. So now I can't figure out why my PC would talk to the PSU yesterday, but not today.
phuz is offline   Reply With Quote
Old 05-28-2008, 10:26 PM   #19
Fox_Mulder's Avatar
I just connected Pin 2 to the GND Pin for the USB cable as Pin 1 & 2 are connected together on M4 anyway. You could connect 1 & 2 together to the Gnd of the USB cable, makes no difference.
lol I have no idea why it would talk before, unless you had switched around the cable or something, no idea - as long as it is working now Whats the software like for the M4?
Fox Mulder
2001 Toyota Avalon Vxi
Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353
Fox_Mulder is offline   Reply With Quote
Old 05-29-2008, 07:57 AM   #20
I did have the wiring correct. Laci just sent me a diagram, but instead of moving descriptions around, he changed the numbers of the pins, so it was correct.
The M4 software is nice...there are a lot of parameters available for change.
Not sure if it was a bug or what...but I just unplugged the USB cable, plugged it into a different port, and it worked again.
Old 05-29-2008, 03:26 PM   #21
Is this software going to be available to everyone soon?
kibble is offline   Reply With Quote
Old 06-11-2008, 01:25 PM   #22
Mp3Car Staff
Fiberoptic's Avatar
I have posted some screen shots of the software over in the store section. We will be adding the USB cable to the store soon.
http://www.mp3car.com/vbulletin/mp3c...ni-review.html
Fiberoptic is offline   Reply With Quote
Earthmate USB to Serial cable New_Compact GPS 22 05-22-2008 02:55 AM
The craziest USB soundcard problem ever Sibi General Hardware Discussion 6 03-07-2008 10:25 AM
USB DVD connection problem with XP bes51659 General Hardware Discussion 11 02-10-2008 12:15 PM
Queer USB 2.0 Upgrade prob. Nukeb32dc2 General Hardware Discussion 8 12-22-2005 06:55 AM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
