Quote: Originally Posted by
GhostRiderDad
Does this model require a minimum amperage of 12 volt to work?
Amps are different from volts.
I am currently bench testing an M4 unit. You are correct, it does not come with a cable to connect to the ACPI jumpers from the M4 to the motherboard. I have fashioned my own out of spare connectors I had laying around.
It does come with a USB cable that theoretically permits programming, but as there is no firmware upgrade or program at this time, it is of no use.
The unit does come with the proper cabling for most motherboards and supplies both IDE and SATA units with power. It also comes with a 4 pin wire for motherboards such as the Intel Little Valley board that require an additional power cable to post.
The documentation is sparse and while it addresses the issue of switching modes and how to reprogram the board to do so, a jumper is not supplied. You will have to find or supply one on your own.
I have not yet hooked the unit up to my motherboard as I have been reading the problems and issues with interest and am checking the functionality of the unit prior to introducing a motherboard into the mix.
