Notices
Old 05-02-2008, 06:03 PM   #1
The correct power supply
I plan on putting together a carputer using this motherboard:
http://h10025.www1.hp.com/ewfrf/wc/d...304167&lang=en
I took the mobo and processor out of a pc I had laying around that I don't plan on using anymore. The pc has/had a 108w psu. I won't be running a cd-rom or a standard HDD (I'll be using a solid state drive).
The problem I'm having finding the right psu is the connector. Almost all the psu units I've come across have a 20-pin atx connector. My mobo has a 24-pin connector.
I'm I blind or am I just missing something?
Thanks!
Mike
Big_Mike is offline   Reply With Quote
Old 05-03-2008, 05:43 AM   #2
v8 scimitar's Avatar
your board needs an ATX 2.2 power supply (24 pin) the car ones are generally ATX 1 (20 pin). You should be able to either splice your old 24 pin connector on or add the extra 4 pins as per wiring diagram http://en.wikipedia.org/wiki/ATX .
Are you sure it had a 108 watt total power supply? That seems far too small for anything Athlon 64 related!
Visit my site V8 Scimitar
SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit.
v8 scimitar is offline   Reply With Quote
Old 05-03-2008, 07:04 AM   #3
hailrazer's Avatar
The M4-Atx has a 24 pin connector.
My 2007 Yukon XL setup. http://www.mp3car.com/vbulletin/show...64-5000-a.html
hailrazer is offline   Reply With Quote
Old 05-03-2008, 07:04 AM   #4
Plenty of 20 to 24 pin ATX cable converters available, try a web search - here is one(checked store first but did not see one) http://www.newegg.com/Product/Produc...re)-_-12201001
Rick99TAWS6 is offline   Reply With Quote
Old 05-03-2008, 08:09 AM   #5
That's what I thought too, but it's true.
Here's the pc it came out of:
http://h10025.www1.hp.com/ewfrf/wc/d...04167&lang=en&
Thanks for the info guys. I figured it was something simple like a converter, but I wanted to be sure that wasn't a problem.
fried my carnetix power supply? mustanglou Power Supplies 2 11-10-2007 12:34 PM
My low cost, easy to build power supply... SkinnyBoy Power Supplies 52 09-27-2006 07:10 PM
Power Supply MrGee Newbie 9 06-21-2006 05:44 PM
power inverter power supply shutdown problem launter Power Supplies 10 09-21-2005 12:12 PM
Power Supply Options? Optikal Power Supplies 9 06-26-2004 06:46 AM
