DSATX nightmare
So I've been using the DSATX for about a month now and it's working ok, except for the fact when ACC dies the PS dies with it. Note: I'm not too happy that I have to buy a Brainstem to fix this issue.
So I buy a Brainstem and unfortunately can't hook it up due to my current layout. A fellow member here pointed me to a website that sold an extension cable which was perfect. I plug the extension cable into the DSATX, brainstem into extension cable, and then plug the brainstem directly into my serial port.
Well like other people on here, with the brainstem connected to the computer, the computer won't turn on. So I unplug the brainstem from the serial port and sure enough it turns on. So with it still connected to the DSATX, I decide to turn on the computer, then connect it to the serial port. Sometimes this works, sometimes not (power shuts off immediately). I wasn't sure if this constituted hotplugging the brainstem because I always have it plugged into the DSATX (via extension cable) - only thing I'm doing is hotplugging it into the serial port.
I finally managed to get into hyperterminal and started hitting keys to make sure I was connected. I then see something to the effect of "Defaults loaded" or something like that. Then about 3 seconds later the power dies. Sure enough I can't turn it back on.
I disconnect the brainstem from the serial port. Again I turn on the computer and try to seat it back into the serial port. Again the computer dies.
Now my current state is I get 4 red blinks on the DSATX and it appears to be stuck in this state. I've completely shut off the car and back on. Pulled the fuse out and its fine. Yes there is a fan connected but this is definitely not a temp issue as the 4 blinks suggests.
This Brainstem has made things go from bad to worse quick!
