Notices
Old 05-03-2008, 09:41 PM   #1
M3 is enough?
I just had my M2 crap out last Friday and need to order a new PSU. Here's my list
EPIA-EN 15000G -17watts?
1GB DDR2 4200 RAM - 4watts?
1 2.5" SATA HDD - 2.5W 5V/7.2W 12V
Lilliput 7" VGA Touchscreen 629GL-70NP converted to the PSU power - 9 watts
Panasonic UJ-85J-B Slim Slot load DVD±R/±RW/+RDL/RAM Multi Drive - 10 watts
Mini-Key USB Keyboard DGPN-570 - 2watts?
USB bluetooth dongle - 2watts?
USB GPS receiver - 2watts?
D-link USB wifi adapter - 2watts?
PCMCIA USB adapter - 2watts?
and sometimes a USB thumbdrive - 2watts?
USB 5.1 surround sound card (ZM-RSSC) - 2.5watts?
HQCT USB -
The M3 should technically be enough juice for the system and since its all behind the screen (in-dash) the smaller footprint, the better. Did I calculate this correctly? Any bad reviews on the M3?
plunderisley is offline   Reply With Quote
Old 05-03-2008, 10:30 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
You cannot calculate these decisions based on total wattage. You have to calculate it based on total current draw for each rail.
Old 05-04-2008, 09:11 AM   #3
OK how would I go about doing that?
Looks like 12V is 6A = 72W
5V is 6A = 30W
and basically everything except part of the SATA and the DVD burner will be on the 5V?
If so, then I got
about 53W on the 12V and about 13W on the 5V
Old 05-04-2008, 11:33 AM   #4
FusionFanatic's Avatar
PSU wattage is used to state a PSU's output power in a single number (total watts). this makes it easier for marketing the PSU, but this number alone is useless in determining if a PSU is powerful enough for your specific system. each power rail has it's own maximum output and power cannot be shifted from rail to rail.
you don't need to calculate the wattage for each rail, in fact you don't need to calculate wattage at all. you need to know how many amps each power rail can provide, and how much current your computer/system needs from each rail.
at ~12v input; the M3-ATX can provide a max 3.3v@6A, 5v@6A, and 12v@6A. since you calculated your system needs at around 6A on the 5v and 12v rails then the M3-ATX will be completely taxed (if it works at all).
I think it's safe to say that M3-ATX is not powerful enough for your system
FusionFanatic is offline   Reply With Quote
Old 05-04-2008, 12:14 PM   #5
So then I'm stuck with the M2. Which M2 though?
M2-ATX 6-24V DC/DC (160 Watts)
M2-ATX-HV 6-32V DC/DC (140 Watt)
or what about the M4?
I think I might just go once again with the original M2 and hope it doesn't crap out again after a year
Old 05-04-2008, 05:10 PM   #6
you're not stuck with anything. you're just choosing PSUs that are not powerful enough for your setup. remember, when searching for a PSU, the total wattage does NOT matter. look only at the power rail amperage ratings. check out the MP3car store's PSU section. there are several DC-DC PSU models that can handle your system. when you read the product descriptions, click on the "technical specs" button (under the product picture) to see the individual rail output ratings.
the M2-ATX and M2-ATX-HV have the same output power (140w max, 160w peak). the only significant difference is the '-HV' model has a wider input voltage range. it's irrelevant in your case anyways because it still can't handle your system with any headroom. the M2-ATX / M2-ATX-HV can provide 3.3v@6A, 5v@6A, and 12v@7A. it's only slightly more powerful than the M3-ATX. your M2 probably died because you were pulling too much juice from it. if you buy another one it will likely die just as quickly.
the M4-ATX is significantly more powerful. at ~12v input it can provide 3.3v@15A, 5v@15A, and 12v@12A. that should be able to easily handle your system, and gives you headroom for future expansion/upgrades.
Old 05-04-2008, 06:11 PM   #7
I'll order the M4, and reading the manual online looks like very little modification is needed to get it to work.
Opinions on the BMW M3 Rith Off Topic 29 05-05-2008 12:27 PM
m3 software for custom times 89ragtopgt Power Supplies 4 03-13-2008 04:06 PM
bmw M3 tom206 General MP3Car Discussion 4 11-15-2006 02:30 PM
M3 Cab with 'Carputer' Forsale CdRsKuLL Classified Archive 7 09-23-2005 12:34 AM
FS: GPS Sharkin Antenna Casing - BMW style X3 & M3 sivart321 Classified Archive 29 08-12-2005 03:35 AM
