Old 07-12-2009, 02:24 PM   #181
Griff1's Avatar
Griff1 is on a distinguished road
I'm afraid i can't help you there as i don't know how to check the firmware.
As i understand it there's only 1 way to do it and thats when the unit is powered up and you have the intelligent cable made up and connected to the software.
In my case, it was just a good guess as i'd had it for ages, i got it just after they came out so i was pretty sure and proved correct.
P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,ROADRUNNER, iGo8, Custom Freedom 2.1
Griff1 is offline   Reply With Quote
Old 08-12-2009, 04:09 AM   #182
seport is an unknown quantity at this point
M4-ATX Input fuse rating
what is the recommended fuse rating to feed the M4-ATX PS? I believe that it should be 20A for the +12V line and perhaps 3A for the Ignition line. Is this correct?
seport is offline   Reply With Quote
Old 09-01-2009, 06:19 PM   #183
nmbal is an unknown quantity at this point
M4-ATX no power problem
Hi,
I red many replies. I had a problem with M4-ATX power supply.
I had connect all wires and after get power nothing happening.
I searched for many hours and didn't find nothing about on internet.
So, i decided to start from the beggining.
I used a external car battery for test.
The also deference was that didn't connect 12V of battery to IGNITION of M4-ATX.
After cut everything worked fine.
If anybody has the same problem, try it to connect only V+ and GROUND.
I hope to help.
Thanks to community.
nmbal is offline   Reply With Quote
Old 09-01-2009, 06:30 PM   #184
M4-atx ignition connector
Hi,
[Copy from manual]
Power Input Connectors (bottom, right)
Left Battery negative (GND) Center Ignition (switched battery, positive. Can test by connecting to Battery +)
Right Battery positive (+)
The bold enclosure text may be is wrong. I spent many hours to strat power supply and i didn't, until I connected only V+ and ground.
It is possible somebody has same problem
Old 09-22-2009, 10:43 AM   #185
sxott is on a distinguished road
Hey does anyone have the dimensions on this unit...
http://resources.mini-box.com/online...dimensions.pdf
That doesn't appear to list the depth, though I might just not know how to read it. I could probably get away with 160W M2 instead, but more is better right...
My Install
sxott is offline   Reply With Quote
Old 09-22-2009, 01:46 PM   #186
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Do you mean height?
Luckily I happen to have mine handy as it's just returned from being reflashed.
Height is 30mm, this is from the highest capacitor to the bottom of the lowest solder joint.
So a space of 35-40mm at minimum I would recommend.
Enforcer is offline   Reply With Quote
Old 09-28-2009, 10:10 PM   #187
Enforcer sorry I did not reply earlier a bunch of things came up, but mucho gracias man. I really appreciate the info. And height is exactly what I was wondering about. That means I will have no DVD drive in my case, no problem though. Just an external USB one instead I guess.
My Install
M4 ATX USB connection Arby Power Supplies 24 08-10-2009 10:24 PM
M4 ATX Turn On Problem Fox_Mulder Power Supplies 26 12-31-2008 08:43 AM
miniITX power supply for ATX motherboard? uldics Power Supplies 4 09-26-2007 01:17 PM
Testing Opus 150 via ATX - Computer is Continually Rebooting long.1 Power Supplies 13 07-19-2007 02:57 PM
morex 80wpsu and reg ATX cable dilema!! surfy Power Supplies 1 08-16-2005 09:06 PM
