Old 10-04-2008, 06:35 PM   #31
kibble's Avatar
kibble will become famous soon enough
Quote: Originally Posted by marc5 View Post
Can i use the 12v accesories plug in my trunk to connect to the earth and ignition point of the m4?
Another thing, is there a polarity for the motherboard switch on jumper?
Yes, if all you're using it for is to turn it on.
No, there's a small analog switch on the m4 that acts like a relay and just shorts those two contacts together to simulate the switch.
Kids, don't play with too many knives! -Crack Stuntman
kibble is offline   Reply With Quote
Old 10-04-2008, 09:25 PM   #32
marc5 is on a distinguished road
much appreciated.
marc5 is offline   Reply With Quote
Old 10-05-2008, 11:17 AM   #33
rijk is an unknown quantity at this point
Quote: Originally Posted by Fox_Mulder View Post
How do I reprogram my M4 ATX?
This requires a bit of soldering and electrical know how, if in doubt just send it back to mini-box for them to upgrade the firmware.
Things you need:
New Firmware (v1.1 attached to this post)
WinPic here
an ICSP (In circuit serial programmer) for the 18F2450 microcontroller, if one of these is not available you will have to build one.
ICSP, can i use my brainstem for this? http://www.acroname.com/robotics/par...-INT-CONN.html
http://store.mp3car.com/Brainstem_TT..._p/com-021.htm
rijk is offline   Reply With Quote
Old 10-05-2008, 11:41 AM   #34
kibble's Avatar
You wouldn't be able to use that because it's a serial level converter not a programmer.
Old 10-05-2008, 06:57 PM   #35
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Anyone having problems with their M4 turning the computer back on after it tells it to shut down?
I've set my PC to shutdown when I turn the car off. No hibernate, no standby. The M4 will shut it down and approximately 1 minute later, it turns it on again. To be sure it doesn't do this, I have to turn the power off to the PC itself.
Anybody experienced this issue? The M4 is a giant hunk O' junk for me. I"m going to go back to my Carnetix regulator and P120 if I can't figure it out. That combination has worked flawlessly for years.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 10-05-2008, 07:13 PM   #36
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Make sure nothing is shorting your Acc line
Enforcer is offline   Reply With Quote
Old 10-05-2008, 07:55 PM   #37
kibble's Avatar
Reset it, maybe?
Old 10-05-2008, 08:51 PM   #38
Bugbyte's Avatar
Reset it, maybe?
I did reset it with no change in results. However, Enforcer's suggestion to check the accessory line is a good one. For reasons that I will not delve into here, I have two computers in the car, both triggered by the same accessory line, which means I have two PSU's in the car.
The PSU for one of the computers seems to have failed (it's buried in the dash and I have to dig it out) and that may have caused a short.
Want to:
-Where is the iBug?
Old 10-06-2008, 04:21 AM   #39
oke, thanks
Old 10-26-2008, 06:00 AM   #40
is there a way to make the m4 switch on the mobo quicker. when it is set to hardoff and the 5 volt rail is gone, it takes 5 sec before the fan starts to spin.
When i use an regular powersupply and unpluged from the 220 volt (us 110 volt) plug it in and directly press the on switch it spins up within a second.
Is there setting in the usb controle sett to speed things up?
Old 10-26-2008, 08:29 AM   #41
GhostRiderDad's Avatar
GhostRiderDad is an unknown quantity at this point
You can change the settings of the startup/shutdown sequences via the dip switches on the unit, or if you have the usb cable hooked up and the software installed, you can changed the settings there. I myself used the dip switches and have not played that much with the usb settings. I think its ok to wait 5 seconds in case you unintentionally turn on the ignition prematurely, and dont want the PC starting up on you. After the 5 second delay, my pc starts up and fully boots in less than 2 minutes. There is a setting on the unit to allow it to function like a "regular" power supply, in that there are no "smart" functionality, but in a car, this is not a good idea, nor do the M4 makers reccomend this for obvious reasons. Good luck, and I hope I answered your questions. You can find the manual and software for the M4 at http://www.mini-box.com/M4-ATX?sc=8&category=13
GhostRiderDad is offline   Reply With Quote
Old 10-26-2008, 09:07 AM   #42
i start the cpc withe the remote of the alarm. M4 on a second litle battery
So the 5 seconds (5 minutes ) wait is not what i want/need. I use the usb / dip 1, changed the setting delay before psu startup from 5 to 0 sec, but that does't make a change. 12v rail startup time 2 ms, 3.3v rail startup time 1 ms.
i think i am overlooking an option.
i use hibernate, makes it a bit quicker in boot. after installing the wifi, i am now on 26 sec from m4 remote switch to RR.
ps watch out for the battery settings, in usb they where someting like 7.5 volts switch off.
Old 10-26-2008, 09:46 AM   #43
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
I'm in the same boat rijk -
this PSU does take a bit longer than even the other DC-DC PSUs on the market to start the start-up sequence.
I'm going to be messing with my PC today in my car, I'll take a look and see if I find anything.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 10-27-2008, 09:06 AM   #44
Bugbyte's Avatar
I've completely abandoned the M4. It was nothing but trouble. Sometimes it would work, sometimes it wouldn't. That PSU has eaten up way more of my time than it was worth.
I've returned to my old but trusty setup of Carnetix 1960 regulator and PW120 and it works flawlessly.
Want to:
-Where is the iBug?
Old 10-27-2008, 03:52 PM   #45
In testing, the m4 has worked fine, only the startup is a bit long.
Big + you can set the time for anti-thum.
M4 ATX USB connection Arby Power Supplies 24 08-10-2009 10:24 PM
M4 ATX Turn On Problem Fox_Mulder Power Supplies 26 12-31-2008 08:43 AM
miniITX power supply for ATX motherboard? uldics Power Supplies 4 09-26-2007 01:17 PM
Testing Opus 150 via ATX - Computer is Continually Rebooting long.1 Power Supplies 13 07-19-2007 02:57 PM
morex 80wpsu and reg ATX cable dilema!! surfy Power Supplies 1 08-16-2005 09:06 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
