Notices
Old 05-18-2008, 01:54 AM   #1
m2-atx Hibernation oddity
I have been using the m2-ATX, it has served me fine. I have finally gotten around to doing some more work on my CarPC and configured it to use Hibernation.
Hibernation seems to work just fine, when I am powering it at home. However, when I have it hooked into the car it still goes into hibernation just fine, but it instantly returns from hibernation at the same time. It seems like the m2-ATX is hitting the power switch, sending it into hibernate, then a second or two later, pushing the power button again causing the system to boot back up. This seems to be a constant issue.
Anyone aware of why this may be and how I may fix it?
Trench is offline   Reply With Quote
Old 05-18-2008, 08:58 PM   #2
update... seems to work fine on my test bench (IE, computer room floor with a bunch of crap piled all around it). I will have to check out the wiring in my car
Old 05-18-2008, 10:48 PM   #3
Maybe its something with your car's electrical system? Hook up a multimeter and see if the +acc wire you hooked the m2-atx to is suddenly coming live or spiking right after you shut the car off.
nobb is offline   Reply With Quote
Old 05-19-2008, 02:43 AM   #4
That is what I am thinking. At first I was thinking perhaps another component (CD Head Unit or Factory Amplifier) was back feeding on the ACC line, so I disconnected them and tried again...still the same deal.
When that did not help I hooked my test light up to the ACC to see if it was popping live a second or two after the initial off, and it did not appear to be so. But, my test light is a standard filament bulb, which takes a moment to light up so if it is just a split second, I doubt it would light up. Unfortunately, I melted my multimeter years ago and never replaced it. I suppose it is about time.
If I can't figure it out, I might have to resort to running a relay or something.
hmmm, I just remembered... It did the same exact thing even before I had everything wired to the ACC line (just finally did that tonight, actually). For my initial "throw it in a see if it works" I just had a positive lead (ACC line) I plugged into the Power outlet in my center counsel. So, I would unplug it, no chance of a sudden charge running through kicking the M2 back on/off.
bah
M2 Atx .. qmm wires? GreenBeauty Power Supplies 10 04-17-2008 11:03 PM
Xbox w/ M2 ATX and PSU convertor MiniRX7 Power Supplies 1 11-25-2007 07:45 AM
m2 ATX 160 Watt - voltage irregular? MiniRX7 Power Supplies 2 11-16-2007 11:32 AM
Did I break my M2 ATX? CelicaGTS Power Supplies 8 04-29-2007 05:36 PM
Wtb :: M2 Atx Dc/dc Psu !!! CoupeE46 Classified Archive 0 01-28-2007 04:06 PM
