Old 05-22-2008, 09:01 PM   #1
Door unlock computer startup controller
hi all,
i roughly looked through the forum and found that there are a few personal projects doing this controller of using the door unlock remote to startup the computer..
i was wondering if theres any ready to install controller on the market or near ready to install controller that will take a few simple configuration to work instead of building it from scratch ....
thanks for all your help guys.
bling23 is offline   Reply With Quote
Old 05-22-2008, 09:34 PM   #2
tigergibb's Avatar
You could have the signal from the button that turns the lights on when you open the car door short the IGN signal to the carputer via a relay. You could then have a pressure sensor under the driver seat that does the same thing.
This way, when the door is open and/or you are sitting in your seat, the carputer will be starting before you even put the key in the ignition.
2003 Nissan Xterra Worklog
Total amount spent so far: $1196.64
You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
2003 Nissan Xterra - Modifications
tigergibb is offline   Reply With Quote
Old 05-23-2008, 12:39 AM   #3
ok.. is there any stuff i can purchase? or do i have to design the circuit diagram and relay myself?
Old 05-23-2008, 12:40 AM   #4
i was thinking more of the press remote to unlock door/activate carputer.
if key not in ignition in half a min, kill power to carputer kinda switch.
The legalities of wardriving. PURDooM Wireless Communications 200 01-29-2008 05:26 PM
Computer remote control for startup black06stang Hardware Development 18 06-07-2006 07:03 AM
WTB DSSC Shutdown startup controller xs10x Classified Archive 3 04-26-2006 05:23 AM
computer freezes at hibernation startup bobthebaker General Hardware Discussion 0 01-12-2005 08:38 PM
Startup pulse fix with Jeff Shutdown Controller moahdib Power Supplies 2 03-03-2004 11:51 AM
