Notices
Old 05-23-2008, 06:22 PM   #1
Stealth915's Avatar
Powering everything from M2-ATX? (Wiring diagram included)
Does everyone use their PSU to power all the components of their CarPC?
This is a quickly drawn up wiring diagram of how I'm planning to wire mine. Does it look about right? I'm not sure whether the external enclosure requires 12V or 5V, as I haven't bought one yet.
Stealth915 is offline   Reply With Quote
Old 05-24-2008, 06:21 AM   #2
v8 scimitar's Avatar
Personally I wouldn't use the chassis grounds, use the grounds on the molex instead.
Visit my site V8 Scimitar
SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit.
v8 scimitar is offline   Reply With Quote
Old 05-24-2008, 06:33 AM   #3
galvitron's Avatar
I agree ^^^ Use the Molex's grounds. The M2 should be connected to chassis ground and all ground from each component should connect to there through your splitter.
Make sure to get the correct gauge wire for the M2's connections to 12V and GND.
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 90%
Installation/Fab/Assembly (Revised v2):
[----------] 90%
galvitron is offline   Reply With Quote
Old 05-24-2008, 03:59 PM   #4
Stealth915's Avatar
is there a reason to use the molex grounds instead of chassis ground? I was going to use chassis ground so I would have to run one less wire to the component I'm powering. Not a big deal. Is the molex ground somehow a more stable ground point than chassis?
Old 05-24-2008, 06:28 PM   #5
Maybe it's just me, but I don't think I'd run all of that off a single M2...
Why not just 1 or 2 Bosch style relays switched on from the M2 to power all the accessories?
WuNgUn is offline   Reply With Quote
Old 05-24-2008, 06:37 PM   #6
eric_barcus's Avatar
id do some seperate power supply for at least the external drive and lillyput or teh lillyput and usb hub, or usb hub and external, id remove two of the components from the M2
eric_barcus is offline   Reply With Quote
Old 05-24-2008, 07:46 PM   #7
bambam's Avatar
I have an Opus 320 and run everything off of it without any problems...very reliable.
"Imagination is more important than knowledge." -AE
bambam is offline   Reply With Quote
Old 05-25-2008, 05:15 AM   #8
Stealth915's Avatar
If I did my power consumption calculations correctly, I should have enough power to run all of my components through the M2. But looking at my wiring diagram again, I realized that the HD Radio doesn't need regulated 12V, so I can just plug that right into my battery. Also, the only USB devices I'll be using are a GPS receiver, wireless keyboard, and USB for the touchscreen, so I guess I won't really need a hub anyway.
So crossing out the HD Radio and USB hub, I shouldn't need another power supply for the Lilliput and DVD drive, right?
M2 Atx .. qmm wires? GreenBeauty Power Supplies 10 04-17-2008 11:03 PM
M2 ATX - EN15000 - USB - Problems! BulleDK Power Supplies 16 12-28-2006 04:29 PM
M2 ATX Manual lanman1 Power Supplies 2 08-16-2006 02:28 PM
M2 ATX Power on problem JWise1203 Power Supplies 5 07-26-2006 12:24 PM
datalux 4x20 red lcd wiring diagram? etrik LCD/Display 0 12-07-2001 04:35 PM
