Notices
Old 05-26-2008, 07:01 PM   #1
M2-ATX + VIA MB Strange Behavior
Hi guys,
I’ve connected my M2-ATX according to the diagram of the product, Black(Ground), Red(Ignition) and White(12V+), but It didn’t work ! after a 2 hours trial & error session, I’ve managed to power-up my Carputer through an external Switch which actually initiates a circuit to the power-supply (M2-ATX) from the Ground and closes it once the car ignition is off (and with the jumper being in mode A it takes some time for the M2-ATX to completely shut-off –which is fine) …
Now what is strange is that after some time (around 20 – 40) mins the MB shuts off and then keep restarting again multiple times before finally being able to normally start??? and that takes around 2-5 minutes ?! then everything is fine …
Does anyone had the same issue before ? I have read some threads where the carputer shuts down automatically, but that’s a different story … so could you please help me out ???
zadjali is offline   Reply With Quote
Old 05-31-2008, 12:30 PM   #2
I've had this problem but it happened when I first started my carpc build 3 years ago. I'll try to remember what fixed it. I know I'm not being helpful but I'm just letting you know that you're not alone.
Leprechaun is offline   Reply With Quote
Old 05-31-2008, 03:52 PM   #3
Thumbs up Omg
Thanks for the support Leprechaun
Actually I decided to open my Voom PC2 case to check what's going on ... and guess what I found One of the capacitors has fallen off the M2-ATX board I guess I wasn't careful enough the last time I closed the case (because of the tons of wires running under that case) anyway I replaced that capacitor and everything is working fine again
Old 06-01-2008, 10:16 PM   #4
good to hear
Old 06-09-2008, 03:05 PM   #5
nice work. do you like that setup? i went with carnetix and i loved mine. but now i got a new car and i just wont put it in..........maybe ill do a project car soon..........
jayrod7387 is offline   Reply With Quote
m2 ATX 160 Watt - voltage irregular? MiniRX7 Power Supplies 2 11-16-2007 11:32 AM
M2 ATX "D1" part dead HELP!!! Elifromthevi Power Supplies 1 07-05-2007 05:00 PM
Micro Atx MB eazyrog General Hardware Discussion 6 08-26-2005 08:37 AM
Micro ATX MB w/ Celeron D ~ no power? bmoney03 General Hardware Discussion 8 01-15-2005 11:54 PM
Wanted: ATX MB + PSU infrared Classified Archive 4 02-25-2002 06:09 PM
