Quote:
Originally posted by AVGeek
I also did not regulate the incoming voltage, and do not use a shutdown controller. I have been using the computer for at least six months in this configuration with no problems. I wired it up using an old Radio Shack power adapter (just cut the cable) and installed the appropriate adapter tip. I put a fuse inline, and tied into the power distro block for my audio system.
I don't understand. You said that you don't regulate the incoming voltage, but that you use a radio shack power adapter, doesn't that imply that the input voltage is actually regulated, via said adapter?
