Old 12-16-2002, 05:47 PM   #1
Casetronics Case and DC Power
I went ahead and wired up my casetronics case directly to my trucks power system. I measured the voltage at my connection points both with and without the engine running (14.3 and 12.5 volts respectively). Computer boots fine, and I added a relay to inhibit the computer from turning on unless the head unit is on (Ensures the PC turns off, as the truck occasionally sits for long stretches).
I am taking a long road trip later this week, and will report back anything that comes up.
AVGeek is offline   Reply With Quote
Old 12-23-2002, 11:22 PM   #2
OK, I am back from the dunes and here is what came up
The power supply works beautifully, absolutely no problems running it for several hours, shutting it off at fuel stops and rebooting once I got back on the road.
My computer does seem to take longer to boot (a few more seconds, no biggie), but I did not clock it to know for sure.
I did run into some software issues, not sure if they are related to the power supply. I need to hook up some sort of display to troubleshoot for sure. Winamp would play songs fine, then go to transition to the next song, and the music would stop. I'd punch the reset button, and the PC would reboot, and Winamp would resume the last song it was actually playing (I am using the Resumer plugin and a keypad plugin, Blackwind's I think). As a side note, can the POST beep on a Epia 800 board be reduced in volume? That thing is damn loud at my normal head unit volume levels.
Old 12-24-2002, 01:28 AM   #3
bosstone74's Avatar
BEEEEEEEEEEEEEEEEP!!!!!!!!!!!!!!!
I found this link for you! Here
I don't know how true it is, but give er' try and let us know how it works!
BossTone74
bosstone74 is offline   Reply With Quote
Old 12-24-2002, 10:03 AM   #4
Thanks boss, I'll look into it
Old 01-06-2003, 07:37 AM   #5
Bj
The EPIA "beep" can be gone forever with the latest BIOS update from VIA. Check it out, it was the first thing I did before actually putting it in a case!
Bj
BjBlaster! Car MP3 & Carputer!
bjblaster.com
"The solution to one problem is only the begining of another"
Bj is offline   Reply With Quote
Old 01-06-2003, 01:49 PM   #6
It's unfortunate that the EPIA-M, still beeps.
You think they would have learned the first time...
-Mario
m3rdpwr is offline   Reply With Quote
Old 01-06-2003, 10:12 PM   #7
I actually don't mind the beep, as I have yet to install any sort of monitor, but I just wish it wasn't so damn loud!
Old 06-01-2003, 06:54 AM   #8
stimps's Avatar
so you cant disable the beep in the EPIA M series, at all? with any bios?
sounds true, coz four of the bios files they released on their web page wont even load into the bios.
hrmmmm...
*beep*
DAMN THING.
Ford XR6T blueprint 4.0 L twin cam turbo.
Xenarc 7" touchscreen M10000 Audigy 2 NX
ITX 120W PS 80gig HD, 256MB Ram, USB wireless internet/LAN
Griffin Powermate Panasonic DVD-CDW
Pioneer 5x7 Four way, 2x12 pioneer subz
600watt 6chan USA audio AMP
stimps is offline   Reply With Quote
Old 06-02-2003, 01:45 PM   #9
How exactly did you wire that system? I am trying to do teh same thing with my battery, but am scared I will damage something...in otherwords what wires go where. Thanks man, I appreciate it
Chronic13 is offline   Reply With Quote
Old 06-03-2003, 09:55 AM   #10
vbi
I'm using a casetronic DC-DC power supply too.
I finished the install last friday and last sunday i had a nice cruise (800miles in a day...). The system was swicthed on for more than 9 hours@14Volts. No problems at all.
Ermanno vbi
TM701L with TouchScreen, Epia M10k, 80Gb 3,5" Hdd, DC-DC PS.
System up and running with GPS and Bluetooth...
Writing software for a Parallel port relay controller.
vbi is offline   Reply With Quote
Old 06-03-2003, 11:16 AM   #11
bosstone74's Avatar
did you regulate it the 12v in? Do you have a shutdown controller for it too?
BossTone74
Old 06-03-2003, 05:42 PM   #12
vbi
I have not regulated the 12v in. I just feed it with the 14v i have when the engine is running. I don't have a shutdown controller, I only installed 3 switch in the dash, one for aplifiers, one for power supply and the last for powering on and hybernating the PC.
I only need a tank circuit to avoid rebooting during cranking.
Also I would like to not ear at that fu@[#n beep when the epia boots....
Ermanno vbi
Old 06-03-2003, 10:02 PM   #13
I also did not regulate the incoming voltage, and do not use a shutdown controller. I have been using the computer for at least six months in this configuration with no problems. I wired it up using an old Radio Shack power adapter (just cut the cable) and installed the appropriate adapter tip (make sure to check polarity!). I put a fuse inline, and tied into the power distro block for my audio system.
OT: I had a problem with some program looking for Internet Explorer. Turns out its nagware in SqrSoft's crossfader program. I don't have IE installed (running Win 98Lite), so it would cause the music to stop. Without a monitor, I couldn't see what was going on, and without a full keyboard, could not hit the esc key. By setting Winamp to Always on Top, it kept SqrSoft from stopping the music.
KG6OQD
www.americansandassociation.org
Old 06-03-2003, 10:04 PM   #14
I also did not regulate the incoming voltage, and do not use a shutdown controller. I have been using the computer for at least six months in this configuration with no problems. I wired it up using an old Radio Shack power adapter (just cut the cable) and installed the appropriate adapter tip. I put a fuse inline, and tied into the power distro block for my audio system.
KG6OQD
Old 06-05-2003, 10:33 PM   #15
I purchased the Radio Shack 60 watt universal adapter and hooked it up to my Casetronic 2699/Epia M9000 with the correct tip polarity.
The adapter fuse blew out .....I can't figure out what went wrong. Unless the polarity sticker on the Casetronic case is wrong, I haven't tried it again.
How did you get it to work and what is your exact setup and components?
mag2 is offline   Reply With Quote
