Old 05-29-2008, 06:55 PM   #1
Raw Wave
lostreception's Avatar
lostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud of
power wattage question
most of the application guides for running amp wires etc refer to how many wats RMS a amp will draw for example
http://www.the12volt.com/info/recwirsz.asp
also they state that it is based on the Power of the amplifier with a 50% efficiency rating.
most psu's like the opus 250 are very high efficient (99-100%?) 95?
so given that situation do these sizes still run true
id like to run 10 ft of 10ga to power the opus but i think that might not be enough but im confused on whther the efficiency matters
-thx lost
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Old 05-29-2008, 07:37 PM   #2
lbridges is an unknown quantity at this point
Efficiency always matters. I have my doubts that it is anywhere near 99%, but that's just me. I would estimate 80%. So, if the max output is 250 watts with 80% efficiency, it will need 312.5 watts on the input side. That translates (roughly) into 26 Amps. Get a wire size using the calculator here http://www.bcae1.com/wire.htm
Remember, fuse to the size of the wire, don't let your car burn down if the wiring shorts.
lbridges is offline   Reply With Quote
Old 05-29-2008, 07:40 PM   #3
h3rk will become famous soon enough
I'd say worst case, your pushing the 250W power suplly at 10 Volts. but check out the input limiting fuse on the power supply. That's the ampacity you need to cover with the wire you choose. So if the fuse is 25Amps, then you can trust the engineering of the supply and say you need a wire that will handle 25 amps minimum. Then use an ampacity table to determine the sixe of the wire... like the kayjayco one I linked to in this thread. 12AWG cuts it close, but 10AWG covers it nicely. I'd say you can implement your plan with no worries. And if the wire goes in the engine compartment, go XLP (CROSS LINKED POLY).
h3rk is offline   Reply With Quote
Inspiron 8500 Power Question joshh385 General MP3Car Discussion 73 06-14-2007 08:27 PM
Question about Laptop Power on/off ashiq32 Laptops, Netbooks, Tablets, UMPCs, etc. 1 02-01-2007 09:11 PM
Does a opus power supplie contain a relay/other question. VandammeS Power Supplies 5 01-10-2007 03:41 PM
Noob question about power supplies Jagojon3 Newbie 10 03-09-2005 12:35 AM
Power Supplies Specs Question rushnrockt Power Supplies 4 02-19-2005 02:34 AM
