Notices
Old 06-02-2008, 06:26 PM   #1
Power's up, Power's down, Power's up....
Hi,
I am trying to troubleshoot a problem with my machine. Specifically, it fails to start. Well, more exactly -- the machine will power up for about 15 - 20 seconds and then power off. In my car this cycle continued over and over again. On the bench, after powering down it stayed down.
Troubleshooting steps:
1. While in car I turned off all power to the computer and then reapplied it (no change -- after several attempts)
2. took out of car and power computer via a ATX power supply through the OPUS. Power's on and then off (stays off)
3. powered motherboard directly from my ATX power supply -- same results as #2
4. Sent motherboard back to company as an RMA. Company verified that nothing was wrong with the motherboard. Included a 15hour Burn In Test...
5. Got board back, plugged in as in #3 with same results as #2....
6. Took out memory module and again tried #3 (same results as #2)
Any Suggestions? I keep my system specs updated on mp3car, so just see the link under my name for them...
Any Help would be greatly appreciated.
Nasa
nasa is offline   Reply With Quote
Old 06-03-2008, 01:28 PM   #2
Do you get an image on your monitor?
Do you get the boot-ok beep from your bios?
I had the same experience when building my car-pc, but for me it was just the powersupply that was not strong enough for my configuration.
If nothing of the above points help you solve it, than i'm afraid i have bad news.
I have the feeling that it will be your cpu that's damaged.
I hope for you that i'm wrong.
Greetz
Enigma666 is offline   Reply With Quote
Old 06-03-2008, 02:00 PM   #3
Thanks for the reply,
No -- I don't get an image
No beep....
Ordered a new DC-DC adapter, hope it helps....
Nasa
Old 06-03-2008, 02:05 PM   #4
Have you tried to start the car and than start up the cpc, it sounds like the battery isn’t giving enough power. So when the powersupply starts it takes away power and the current of the battery falls. When it hits the safety, it will turn of the mobo, thus giving the battery the change the recuperate, than there is enough power for the powersupply and it switches the mobo back on, etc...
rijk is offline   Reply With Quote
Old 06-03-2008, 02:19 PM   #5
Do you have a chance of testing your config with another cpu?
If your motherboard is tested, you can be sure that it's ok.
If you use your atx-supply in your pc, you can be sure that ok as well.
you removed the memory, no error-beep's?
I'm thinking CPU
Greetz
Old 06-03-2008, 02:34 PM   #6
Unfortunetly, I don't own another cpu of that type...
The ATX power supply is a spare one, so I haven't been using it in any other system.
Removing the memory resulted in the same problem (no beeps) -- I had expected it to at least stay powered....
Old 06-03-2008, 09:29 PM   #7
Try another supply.
If the ATX is a spare one, you have no idea if its providing enough power. Use the one youre using in your normal computer and see what happens. If you're not getting the beeps, it means that either (like they said) youre not getting enough power OR your cpu is fried. More than likely youre not getting enough power since cpus dont just fry like theyre made out to...
colin is offline   Reply With Quote
Old 06-04-2008, 06:13 AM   #8
greatwhite's Avatar
Does sound like a power problem to me.................
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 06-04-2008, 06:21 AM   #9
Fusion Brain Creator
2k1Toaster's Avatar
The CPU will draw less than 65W, any old power supply even uATX supplies will power the whole thing no problem. Obviously check that the PSU is ok, but my money is on the cpu.
What is the serial number of your CPU? The whole Socket M, Socket P, Socket 478/479 thing for these core duo, core 2 duo, core solo chips is a nightmare. You could have an incompatible cpu without knowing it. If you have a socket P chip and it is supposed to be a socket M type thing. Since your specs list it as a solo/duo then you are supposed to have a Socket M. And with these new Intel chips not all with the same model number are the same cpu socket.
Old 06-04-2008, 06:28 AM   #10
My CPU is this one:
http://store.mp3car.com/ProductDetai...ctCode=CPU-007
I have ordered a new PSU, hopefully I will get it today (crosses fingers) -- will report back findings....
Old 06-04-2008, 06:36 AM   #11
2k1Toaster's Avatar
Quote: Originally Posted by nasa View Post
My CPU is this one:
You realize "Core Duo" and "Core 2 Duo" are completey different beasts.
Your motherboard does not support Core 2 Duo.
Old 06-04-2008, 07:25 AM   #12
Although the specs listed on mp3car state only "core duo" the instruction manual for the board states:
MB899
Intel ® CoreTM 2 Duo/
CoreTM Duo/ Solo 945GM
Mini-ITX Motherboard
Also given I have used this system for over 6 months, I don't think my issue is one of incompatibility (at least I hope not).
Old 06-04-2008, 07:45 AM   #13
although cpu's have some protect against overcurrent, it's really not that great. Thermal protection is ok for most cpu's.
My bet is still the cpu.
Greetz
Old 06-07-2008, 03:34 PM   #14
Ok,
It was the power supply....
Board only powers for a few seconds. Profozone General Hardware Discussion 12 06-27-2007 01:33 PM
Screen powers off, but touchscreen still works? andrewt LCD/Display 7 12-08-2006 07:29 PM
8" Lilliput touchscreen NOT WORKING but powers up! HELP!!!! Tibby93 LCD/Display 5 04-30-2006 03:52 PM
laptop powers off corsamel General Hardware Discussion 0 02-01-2004 08:02 AM
JVC powers down when crankin xces Power Supplies 4 01-23-2003 05:10 AM
