Old 06-03-2008, 08:45 PM   #1
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
P4 Connector Voltage
Dell motherboard stated showing a steady amber power light which according to the troubleshooting manual could be an internal power problem. I had rigged a P4 connector (joined to ends) from the M2-ATX to the MB and wasn't very tidy joining the wires so i figured that was the problem; redid everything like it was supposed to be in the first place; reconnected; powered-up - same thing! steady amber light
Something told me to test the voltage and i get 0.00 volts from the P4 connector. I'm pretty sure there should be some voltage reading but i just want to confirm
What voltage reading should i get for the M2-ATX P4 connector??
Thanks in advance
treetop777 is offline   Reply With Quote
Old 06-03-2008, 09:42 PM   #2
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
The P4 connector should have 2x12v and 2xground rails. They're separate rails because some CPUs draw more power than a single rail should supply...
I rigged one up the same way with two ends and some electrical tape Works like a charm...
colin is offline   Reply With Quote
Old 06-03-2008, 10:11 PM   #3
Raw Wave
treetop777's Avatar
Yeah, mine worked also for a while, i think the M2 went bad for some reason 'cause I'm not getting any voltage reading. The strange thing is that other than that, every thing else is working - the fan is spinning, the motherboard light come-on, i can hear the HHD spin-up and the computer light is on (indicating a fault); all i get at the lilli is "no vga signal"
Oh well, off to buy another one.
Thanks.
What is best: small epia1000 or big p4 2.2 xpluis General Hardware Discussion 6 11-30-2006 09:48 PM
Trying $145 Migrus P4 itx for second install VehicrossPC General Hardware Discussion 2 02-25-2006 10:03 PM
power requirments for p4 SuperFastCVT Power Supplies 6 01-02-2006 11:29 PM
p4 MOBO Recomendation septicdeath General Hardware Discussion 5 01-22-2005 05:31 PM
MII-12000 or my spare P4 for carputer Bootbox General Hardware Discussion 9 09-20-2004 03:11 PM
