Notices
Old 06-06-2008, 12:20 AM   #1
Power question for my first setup of Carputer
Hello,
This is my first post and first ever project to any car. I tried reading lots of thread, however no luck figuring out questions I have.
Now I am going to use a laptop for this project. For LCD screen I am going to use Lilliput 7" screen. I believe it comes with lighter adapter.
I am thinking that I should buy lighter splitter so I have two female cigarette adapter. I am going to cut male part out to get to two female adapter. My question is for LCD screen where would I plug end of this female adapter so it gets power? Same with Laptop?
Also Is this doable with Webmaster's laptop kit?
d3siboy is offline   Reply With Quote
Old 06-06-2008, 02:12 AM   #2
tundra2000's Avatar
im not sure i understand what youre saying... are you saying you want to power a laptop AND your monitor off of one cigarette outlet?
-personally, i would figure out a way to wire your monitor off of a more stable 12V line than the car's battery. as you have read, the voltage fluctuates a lot with the battery, and although your monitor can take it, it prefers not to and will lengthen its life if you give it a stable 12V.
-as for the laptop, you could power it by a cigarette outlet, just doesnt make for a clean installation. also, if the outlet isnt switched, you might have to worry about it draining your battery while youre not using the laptop.
-dont know anything about Webmaster's laptop kit so i cant help you there.
>>hope some of this helps. again, not sure if i answered your question(s)
EDIT: just found this thread 2 threads below this one:
http://www.mp3car.com/vbulletin/powe...g-diagram.html
>similar set up.
tundra2000 is offline   Reply With Quote
How do I power a carputer cube/gaming pc? cortewardy Power Supplies 4 01-20-2008 09:00 PM
DSATX Power My Setup? TeamRSX Power Supplies 9 12-23-2007 12:13 PM
Carputer wont power up once Amp is installed Legrath Newbie 6 03-20-2007 11:16 PM
My 2006 Scion xB (portable) Carputer setup! w/pics! breaker021 Show off your project 26 01-05-2007 10:34 AM
Quick question - yes or no on power supply ckny Newbie 6 10-11-2006 12:44 PM
