Old 06-07-2008, 12:15 AM   #1
Help required for this SMPS Battery Charger
Hi! The attached file is a schematic of 50KHz SMPS power supply which uses 325 VDC (after rectification of Mains 240 V). The required current for charging Lead Acid battery is approx 20 Amperes. Please give comment if any modification in the circuit is required. (note: isolated 12V DC is used for control circuit)
Voltage regulation is not necessary.
Last edited by xyz9915; 06-07-2008 at 05:45 AM. Reason: updated IR2110 Pins connections
xyz9915 is offline   Reply With Quote
Old 06-07-2008, 11:18 PM   #2
The changes/modification proposed by the friends, and thinking that the half bridge topology is better for converting AC mains voltage to low voltage, the modified circuit is attached herewith with feedback control circuitry to keep the design stable. Please point out if any further modification is required.
Old 06-08-2008, 11:10 PM   #3
Thanks for helping & providing tips to build the charger unit.Following modification in the circuit is made with Opto feedback control circuitry to keep the design stable. Opto is used for a simple current regulation. Please point out if any further modification is required.
2nd battery + computer controlled lighting jparks27 Show off your project 22 06-02-2006 08:52 PM
FS: Stealth I Regulated Backup Battery Charger (ebay) e_z_street Classified Archive 0 05-09-2006 07:26 PM
MPJA - MECI ASTEC DC-DC Converter Luc General Hardware Discussion 39 11-22-2004 09:31 PM
laptop battery pack charger? mrzigzag Power Supplies 0 12-07-2003 06:36 AM
Can I put an extra battery in my Chevy? Mastiff Power Supplies 12 04-04-2003 02:19 PM
