Notices
Old 06-08-2008, 07:57 PM   #1
FAQ Using Carnetix CNX-P2140 with Tank Circuit
Got a newbie question for you folks out there. I have seen multiple varieties of Startup/Shutdown controllers and also tank circuits. As far as I can understand most of the Startup/Shutdown controllers do not directly interface with a backup battery to help keep the CarPC from rebooting during engine cranking. So my question is would this work. Installing a tank circuit (specifically the Tank EZ circuit found here: http://carpc.kyferez.com/Products/products.php?id=10) then put in place the Carnetix CNX-P2140 so as to prevent the carPC from premature shutdown.
The reason I am wanting to do this is I am installing this system in my vehicle that I do baggage deliveries in and this requires multiple stops on any given run.
Any help given will be GREATLY appreciated.
Thank you in advance.
Russell Albright
ralbright is offline   Reply With Quote
Advertisement Sponsored links
Battery based tank circuit (tested) Ricky327 Power Supplies 241 02-13-2008 05:43 PM
Question about the Diodes used in Ricky's battery based tank circuit nobb Power Supplies 4 08-15-2006 09:20 PM
Tank circuit using a Solenoid instead of a Diode or diode isolator lakorai Power Supplies 2 05-29-2005 03:29 AM
Tank circuit design + help needed. Arathranar Power Supplies 39 11-23-2004 07:52 PM
FAQ: Tank Circuits (Adding a Second Battery) starfox The FAQ Emporium 0 01-08-2004 09:23 AM
