Notices
Old 06-10-2008, 11:50 PM   #1
which mp3car power supply suits my pc board?
Hi all,
i am installing my carpc, i use pc board ECM-CX700 from avalue.com.tw. pix is here
i am now using an ATX PSU from my old desktop to power it up as a work bench power supply. setup has completed with great RR front end now is the time to put it in the car but i dont have a PSU with startup shutdown controler
i checked out mp3car store and dont really know which one is suitable for my mobo as it doesnt have normal 20 pin atx connector but only a 4 pin (see pix)
could someone please advise which PSU is suitable
thanks
qha_vn is offline   Reply With Quote
Old 06-12-2008, 03:04 AM   #2
40 reads, no advise. would it be that hard?
Old 06-12-2008, 07:08 AM   #3
Neither darque nor pervert
DarquePervert's Avatar
I suggest a 12v regulator.
I also suggest reading the FAQs about choosing a power supply: http://www.mp3car.com/vbulletin/advfaq.php
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 06-12-2008, 10:24 AM   #4
FusionFanatic's Avatar
according to the specs for that board (on avalue.com.tw), it can be powered with a "Single 5V ATX or 5V/12V ATX Power Input".
power consumption is:
  • Power Consumption: +5V@3.5A, +12V@0.1A (with VIA Eden 1.5GHz & 1 GB DDR2 533 SDRAM)
  • Power Type: AT/ATX Power
"intelligent automotive ATX PSUs" have built-in startup/shutdown controllers. the M1-ATX can handle that system with ease (and it's the cheapest "intelligent" PSU in the MP3car store ). it can provide 10A@5V and 2A@12V which leaves you plenty of headroom for additional components. use a laptop HDD (which gets its power from the 5v rail) and you'll have enough power on the 12v rail to power your monitor (most 7" or 8" LCD monitors use less than 1A).
good luck
FusionFanatic is offline   Reply With Quote
Old 06-12-2008, 05:29 PM   #5
But it's also specifically designed for an ATX board.
I'm not saying it can't be used or wouldn't work. But there are cleaner, more elegant solutions for this setup.
My Worklog
Old 06-12-2008, 07:03 PM   #6
I would think that an "all-in-one" device like the M1-ATX (or other intelligent PSU) is the most 'elegant' solution possible in this case...
otherwise you would need 2 or 3 separate devices to get the equivilent funtionality. you would need a startup/shutdown controller, +5v DC-DC regulator, and [possibly] a +12v DC-DC regulator.
Old 06-12-2008, 10:48 PM   #7
thanks all for your inputs, i also think M1-ATX looks ok for my mobo, but i am just wondering how the board communicate with M1 for turning on and off the PSU if i dont use the 20 pin ATX connector
Old 06-14-2008, 09:05 AM   #8
Considering the M-series PSUs are designed for an ATX motherboard (which this is not), you have to "fool" the PSU into recognizing a connection (shorting pins 13 & 14 on the 20-pin ATX connector).
In my mind, that's not particularly elegant.
There are 12v DC-DC regulators available that need nothing more than a connector for the motherboard.
Hey wow...
A Carnetix P2140 has all of this built-in.
Looks pretty elegant to me....
But what do I know. I've only installed a few vehicle PCs...
My Worklog
Old 06-14-2008, 12:39 PM   #9
true... but that's very easy to do.
true... but that doesn't make it any easier.
Hey wow...
it has the features built-in, but it can only provide 3A on the +5v [secondary] output. that motherboard requires at least 3.5A @+5v. 2 separate devices would still be necessary. not very elegant if you ask me
Old 06-18-2008, 12:59 PM   #10
But if your mobo can take 12v and not just 5v, you can still use the 2140. The 12v primary line provides 11 amps
CarPC status:
[XXXXXXXXXX] 100% Complete
[XXXXXXXXXX] 100% Installed
[XXXXXXXXXX] 100% Software
CarPC v1.2 is now in effect. Software updates and hardware additions to come.
KryptonianJorel is offline   Reply With Quote
What Power Supply for Laptop Install? D3LTR33 Newbie 6 08-04-2008 07:41 AM
Car Battery Charger / PC power supply stpenn123 Power Supplies 0 01-28-2008 12:33 AM
Casetronic C137 120watt power supply Change Power Supplies 2 11-13-2005 09:15 PM
PC power supply - no external power switch Zombietime Power Supplies 12 11-29-2004 10:22 AM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 10:29 PM
