Notices
Old 06-15-2008, 11:20 PM   #1
turk's Avatar
Just wanted to check about wiring
I wanna make sure I am on the right track. To wire my psu, m2-atx, to the car battery, I am gonna run a 8 gauge cable from the battery (+) with a 60 amp fuse near the battery. Then I need to downsize the cable to whatever size m2-atx cables are. They look like a 14 to me I'll find out for sure or you can tell me Do I have to use a distro block to go from 8 awg to smaller? Can that be done via just a fuse since I am not hookin anythin else for the power And also I can just extend the ignition wire to the radio power and splice into it right? I would only need a fuse there?
Thanks for the help
________________________
The Turks are in Vienna
Turkiye 3 - Czech Republic 2
turk is offline   Reply With Quote
Old 06-16-2008, 06:55 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
No, you don't need a distro block.
There are cable gage reducers you can get at electronics shops. You can also solder a short piece (a couple of inches) of the thinner wire to the larger piece and cover with heatshrink.
And yes, you can simply tap into an acc line from the radio harness. You don't need a fuse on that line.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 06-19-2008, 08:21 PM   #3
turk's Avatar
Thanks a lot.
Need Help - BMW's Signal Differential Speaker Wiring, Amps and SVEN4 lloydy Car Audio 8 02-14-2006 07:43 PM
Please Double Check My Wiring... Shelbrain Car Audio 6 12-29-2005 10:02 PM
if you designed a vehicle's interior and wiring, how would you do it? stapan General MP3Car Discussion 7 12-26-2005 02:56 PM
Recommendations for amp wiring kits... hd54321 Car Audio 5 08-17-2004 07:02 PM
My Current Wiring Diagram, Opinions Wanted :-) rave5096 General Hardware Discussion 13 08-27-2001 09:13 PM
