The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 06-16-2008, 10:50 AM   #1
alansupra94's Avatar
Vehicle: 1994 Toyota MKIV Supra
My Photos: (0)
DC-AC-DC power supply or DC-DC powersupply
I was wondering what is the best and most reliable way to power the computer.
I am running a GX240 motherboard with a 2.4Ghz P4 and 512MB. I am also installing two 500GB SATA drives, possible an external HDD and a DVD-RW drive. Still not sure on a graphics card but I think I am leaning to an old FX5200.
I already have a 300W inverter running to a ATX powersupply but I am not sure if it can keep up and before I buy a 500W or 1000W one I might as well ask if the DC-DC ones are better
Alan
1996 Toyota Supra NA-T
Boostwerx T-61 w/ TT intake manifold
MAP ECU 2
@ 8psi making 320rwhp
@ 24 psi making 480rwhp
1988 Toyota Celica All-Trac
CT26 turbo w/ aftermarket wastegate and BOV
@ 12psi making 250awhp
alansupra94 is offline   Reply With Quote
Sponsored Links
Old 06-16-2008, 11:14 AM   #2
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (29)
Over 300 watts you are going to need to go with the inverter. The first thing you need to do is figure out how much power your computer draws. Go to either the FAQ's for links to power calculators or the FAQ Emporium for even more FAQs.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 06-16-2008, 11:20 AM   #3
My Photos: (0)
sweet thanks for the fast responce...yeah I might just buy a 1000W inverter and rest easy
I just wonder how much battery it would drain.....
MAP ECU 2
Old 06-16-2008, 01:54 PM   #4
Bugbyte's Avatar
My Photos: (29)
Well, it isn't the inverter that drains the battery -it is your computer. Just because the inverter says it can supply 1000 watts doesn't mean that it draws 1000 watts at all times. If you have nothing hooked up to it, it should draw near zero. If you have a 400 watt PC connected to it, you will see it drawing a little north of 400 watts (there's some level of inefficiency in the device).
I do know that some inverters tend to draw a small amount of power even when the computer is turned off and will eventually drain the battery. You have to switch them physically off to prevent power draw.
Old 06-16-2008, 02:06 PM   #5
Raw Wave
TruckinMP3's CarPC Specs
TruckinMP3's Avatar
Vehicle: '02 suburban with quad captain seating
My Photos: (0)
figure out what your system will draw for power and buy a DC to DC supply.
It will save you from buying an inverter then later a DC to DC option when the inverter does not work well.
TruckinMP3
D201GLY2, DC-DC power, 14in LCD ;) 3.5 inch SATA
Self Proclaimed Spoon feeder!
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 06-16-2008, 04:31 PM   #6
My Photos: (0)
Well the thing is that I doubt any DC-DC powersupply will be able to power my computer
It is basically a full computer.....in a custom stainless steel case that I am making
MAP ECU 2
Old 06-16-2008, 06:39 PM   #7
Vehicle: 2004 Honda Civic Hybrid
My Photos: (0)
Do not go with an inverter -they are very loud and you will get a ton of buzzing on but up and sirius, xm, hd radio, or any other radio you put in. I am dealing with it as we speak. Invest in a set up that you can use a AC to DC adapter....your will be better off in the long run.
Cameron
cameronlazzari is offline   Reply With Quote
Old 06-17-2008, 08:20 AM   #8
Bugbyte's Avatar
My Photos: (29)
Inverter installations without noise *can* be done. Just ask Enforcer. And DC-DC setups can also experience noise. Two of the primary rules are to ground everything to the same point, which reduces the chance of a ground loop and don't run your power wires next to your audio wires.
Old 06-17-2008, 11:39 AM   #9
bambam's CarPC Specs
bambam's Avatar
Vehicle: 1995 Mitsubishi 3000GT SL
My Photos: (0)
Alan
I use an Opus 320W and power my ASRock 775i65G MB with 1G ram, 500G Seagate HD, 8.4" lilliput, 2 fans, usb hub and 5 usb devices with no problem. On my test bench, I also had a 2nd HD and a DVD drive.
As far as noise, I have absolutely none. I grounded everything to a single ground (including the MB) and use a PAC SNI-1 Ground Loop Isolator & RCA Noise Filter.
My project can be seen here:
here
Side note: I use onboard graphics and it plays all the movies, etc. that I throw at it so unless you are playing high end games (graphics), do you need a video card for more power drain?
"Imagination is more important than knowledge." -AE
bambam is offline   Reply With Quote
Old 06-17-2008, 02:48 PM   #10
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Have you read the FAQs on POwer supplies?
http://www.mp3car.com/vbulletin/advfaq.php
A full computer as opposed to... what? A thin client terminal? A WinCE device?
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Sponsored Links
Old 06-17-2008, 03:26 PM   #11
Chairboy's CarPC Specs
Chairboy's Avatar
My Photos: (0)
He may be operating under the assumption that we use hopped up abacuses and Apple ][s in our cars. :P
Alansupra: Inverter installs have a high failure rate in the sense that lots of people who start with them in mind end up either switching to DC-DC later or get rid of their carputer in frustration because of the hassle of day to day use. I'm sure a bunch of inverter users will jump in and tell me how wrong I am, but I know three folks personally who ditched their carputers because of inverter woes.
Also, the big stainless case doesn't actually increase your power consumption. Just an FYI.
Chrysler 300 - Fabricating
http://hallert.net/
Chairboy is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
What Power Supply for Laptop Install? D3LTR33 Newbie 6 08-04-2008 06:41 AM
dc - dc power supply vs. an inverter deepdivered Newbie 1 01-05-2006 09:42 AM
FS: ITPS shutdown controller and PW-70a MINI-ITX power supply hanzacra Classified Archive 4 08-07-2005 10:32 PM
AC or DC power supply w/ tablet pc? gutterslide Power Supplies 2 04-07-2004 03:12 AM
morex dc dc power supply again susman Power Supplies 4 04-12-2003 02:39 PM
Sponsored Links
Ad Management by RedTyger
