Quote: Originally Posted by
alansupra94
I was wondering what is the best and most reliable way to power the computer.
I am running a GX240 motherboard with a 2.4Ghz P4 and 512MB. I am also installing two 500GB SATA drives, possible an external HDD and a DVD-RW drive. Still not sure on a graphics card but I think I am leaning to an old FX5200.
I already have a 300W inverter running to a ATX powersupply but I am not sure if it can keep up and before I buy a 500W or 1000W one I might as well ask if the DC-DC ones are better
Alan
I use an Opus 320W and power my ASRock 775i65G MB with 1G ram, 500G Seagate HD, 8.4" lilliput, 2 fans, usb hub and 5 usb devices with no problem. On my test bench, I also had a 2nd HD and a DVD drive.
As far as noise, I have absolutely none. I grounded everything to a single ground (including the MB) and use a PAC SNI-1 Ground Loop Isolator & RCA Noise Filter.
My project can be seen here:
here
Side note: I use onboard graphics and it plays all the movies, etc. that I throw at it so unless you are playing high end games (graphics), do you need a video card for more power drain?
