The MP3car.com Store
Thread Tools Display Modes
Old 06-17-2008, 10:35 PM   #1
Vehicle: 2005 Civic LX
My Photos: (3)
Is my P1900 going bad, or an I missing something
Aright guys and gals, I've got a problem that is baffling me...
I've had my CarPC up and running fine until recently. I have a P1900 with a MacPac cable to my mac mini. I just recently did two things: I disconnected the mini did some software updates, and I added the +5v add-on for the P1900. Shortly after that, the CarPC has been acting a little erratic. Sometimes it will start up no problem with the ignition (or the power switch I added inline with the acc line), but, most times it wont start. The acpi cable is installed correctly, and even if it wasnt, it still wont turn on via the mini's power button. The power cable is nice and snug (checked 3 times). The P1900 powers up fully, as the screen gets power and the fans whiz on. The LED sequence is normal and remains solid red when on. Also, sometimes, when the mini does turn on, it will make (what i assume is a BIOS code) loud beep. Just one, long beep.
Well guys, any tips, suggestions, or prayers are appreciated
CarPC status:
[XXXXXXXXXX] 100% Complete
[XXXXXXXXXX] 100% Installed
[XXXXXXXXXX] 100% Software
CarPC v1.2 is now in effect. Software updates and hardware additions to come.
KryptonianJorel is offline   Reply With Quote
Sponsored Links
Old 06-18-2008, 10:22 PM   #2
My Photos: (3)
bump
CarPC status:
Old 06-18-2008, 10:34 PM   #3
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
1 beep in a mac is usually RAM missing I think... Or was that the old code with the PowerPC processors? Anyways, what mac do you have? IBM or Intel?
I would check to make sure the RAM is seated well and didnt get bumped loose.
Old 06-18-2008, 10:40 PM   #4
2k1Toaster's Avatar
My Photos: (1)
Also does your power led (the one that flashes when it is in S3) flash at all either?
Old 06-19-2008, 10:19 PM   #5
My Photos: (3)
I have an Intel mac. Yeah, i looked at the POST codes, and it does mean no ram, however, if it had no ram, it wouldnt reboot and magically work. And if my ram was loose, it should beep at me every time I try to start it, right? No, the power LED doesn't flash or anything.
CarPC status:
Old 06-25-2008, 03:06 PM   #6
My Photos: (3)
False alarm. Turns out the connector I made the acpi was touching the metal top of the mac mini AGAIN. The hot glue I used to prevent the connection had worn away. Thanks for the help!
CarPC status:
Sponsored Links
vB code is On
Trackbacks are Off
VIPER TV Show NiN^_^NiN Off Topic 414 10-18-2006 11:27 PM
Carnetix P1900 jorgenjl Newbie 5 06-22-2006 12:08 PM
P1900 + Dell Laptop and docking station wittless Laptops, Tablets, UPMCs, etc. 11 01-07-2006 12:20 AM
Auto power off accord General Hardware Discussion 29 08-15-2004 07:08 AM
Bad Serial Ports on EPIA M9000 wi77iam General Hardware Discussion 6 05-06-2004 11:49 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
