Notices
Old 06-18-2008, 08:15 AM   #1
ivanmx6's Avatar
Replacing an ITPS
Hi,
I've just bought a Lilliput DY-845 PC with an ITPS built into the case.
I understand from reading here that the ITPS is not really suitable for in-car use as it can't handle cranking, so I want to replace it.
I need the PC to be able to start and shutdown remotely (ign key) and have battery drain protection.
I've read the FAQs and have looked into the power requirements:
The PCs power drain is apparently 40W but I'll also be attaching USB GPS, USB WiFi adaptor, a small USB hub and occasionally a USB keyboard.
I've looked at the M2-ATX which seems suitable but there are so many out there it's difficult to see the wood for the trees. My budget is about £50.
What would you recommend?
Thanks.
ivanmx6 is offline   Reply With Quote
Old 06-18-2008, 09:29 PM   #2
DSATX, or Opus150, both great products!
Punky is offline   Reply With Quote
Old 06-19-2008, 01:43 AM   #3
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
M2 will work just fine for you.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 06-19-2008, 07:08 AM   #4
ivanmx6's Avatar
Cheers
M2-ATX ordered. The DSATX is almost 3 times the price.
Old 06-21-2008, 05:43 AM   #5
ivanmx6's Avatar
Fitted and working a treat.
Had to splice a couple of cables as the connectors were different, but that was only a 5 minute job. The worst bit was trying to mount the bu66er securely as the ITPS used custom pillars.
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
Itps Bugbyte Classified Archive 0 10-08-2005 03:40 PM
Powering Theory...input welcome. oekundar Power Supplies 2 07-18-2005 03:25 PM
ITPS Startup Shutdown Controller Not Working EBJUSTIN Power Supplies 4 09-11-2004 09:04 PM
ITPS and Voltage drop issues Wiredwrx Power Supplies 7 04-20-2004 07:09 AM
