Notices
Old 06-22-2008, 12:33 PM   #1
dLockers's Avatar
m2-atx, not working?
got 12v power, enough amps etc, 12v remote line and a ground
it worked perfectly, but ive had the pc out-of-action for a while so it hasn't been used. tried it today and it won't work - all the connections are fine and the PSU itself looks A1 condition. the pc just doesn't start up, no noises, no smells, no nothing.
how can I test the PSU to eliminate this? or is this a common problem?
i'm confused with what to do as i started building this computer LAST year (almost 2 years ago now) and i'm finally at a stage to put it in
edit: I cannot bridge the power connection on the pc itself either
dLockers is offline   Reply With Quote
Old 06-22-2008, 08:17 PM   #2
FusionFanatic's Avatar
the first thing(s) you should do is double-check your power/remote/ground wires and fuses...
1. fuses: the M2-ATX has an on-board fuse and you should have a fuse at the source of your power and remote wires as well.
2. power/remote: use a multimeter to verify that there is ~12v on the power and remote PSU terminals.
3. ground: make sure you have a good, clean ground. factory bolts are often bad ground points due to panel paint and bolt coatings. make sure the ground ring contacts a clean, unpainted, uncoated metal chassis/floor panel.
good luck
FusionFanatic is offline   Reply With Quote
Old 06-23-2008, 04:20 AM   #3
dLockers's Avatar
1. fuses - all are okay, i have 2 40amps on the live wire
2. power/remte - all 12v and making a circuit (I get 12v on the ground to power)
3. ground is fine (varified)
Old 06-23-2008, 05:06 AM   #4
dLockers's Avatar
I think I found the problem, underneath there is a copper wire, tiny little thing, less than a mill thick and its deattached from what looks like 3/4" solder spot away.
Wish me luck, I have no idea how i'm going to repair this
Engine Noise with M2 ATX lucky1 Power Supplies 33 03-03-2008 09:54 PM
Xbox w/ M2 ATX and PSU convertor MiniRX7 Power Supplies 1 11-25-2007 07:45 AM
m2 ATX 160 Watt - voltage irregular? MiniRX7 Power Supplies 2 11-16-2007 11:32 AM
M2 ATX with remote starter question? david69leonard Power Supplies 1 02-05-2007 06:50 AM
Problem m2 atx and 3.5" hard drive Mitski's Rider Power Supplies 2 10-05-2006 12:52 PM
