Notices
Old 06-22-2008, 04:54 PM   #1
M2-ATX Wiring Configuration
I looked at the FAQ for this, but it doesn't look to have a definitive answer in it...
Is there polarity on J8?
Also, I just connect J8 to my mboard's SWITCH jumper and J9 to my PC case's power button?
Carputer Progress:
Re-do fabrication of screen [DONE]
Wood faceplate for computer in glovebox [0%]
fatejd is offline   Reply With Quote
Old 06-24-2008, 04:21 PM   #2
Stealth915's Avatar
there's no polarity on J8. It's basically an open circuit - the switch shorts the two pins together, closing the circuit and telling the computer to turn on.
Correct. Connect J8 to the motherboard's On/Off switch, and your case's power switch to J9. J9 is only needed if you want to manually turn the computer on/off via the switch.
2004 Mazda3 Carputer Worklog - Update 9/12/08: INSTALLED!
Stealth915 is offline   Reply With Quote
Problem with M2 and PC reboots LaroCroft Power Supplies 1 05-19-2008 06:18 PM
m2 ATX 160 Watt - voltage irregular? MiniRX7 Power Supplies 2 11-16-2007 11:32 AM
m2 atx slantman Power Supplies 11 08-08-2007 05:45 AM
M2 ATX Power on problem JWise1203 Power Supplies 5 07-26-2006 12:24 PM
M2 Problem, Some advice please from those with the 'turn on' issue.... Mrcat88 Power Supplies 6 07-06-2006 11:28 PM
