The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 06-24-2008, 02:22 PM   #16
kibble's CarPC Specs
My Photos: (0)
I would feel safer putting some sort of transistor driver on the line though to boost the amperage that it can drive. The serial port outputs really aren't made to source or sink much current.
kibble is offline   Reply With Quote
Sponsored Links
Old 06-24-2008, 02:31 PM   #17
Raw Wave
Rob Withey's CarPC Specs
Rob Withey's Avatar
Vehicle: '97 Vauxhall Corsa 1.5 TD
My Photos: (0)
Quote: Originally Posted by HiJackZX1 View Post
AHHHHH, ok I learned something new, I didnt think 12V could run safetly through such a small wire......
The current has more to do with the size of the wire than the voltage.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 06-24-2008, 03:01 PM   #18
HiJackZX1's CarPC Specs
HiJackZX1's Avatar
Vehicle: 03 Dodge Durango SLT
My Photos: (254)
I think I agree, I just started noticing that when I turn on the PC with AMPCTRL it takes almost a minute for the amps to come on, and when it does it fades in as though the amps are fighting for the wire to send the signal to power them on. On my setup I have a thin wire coming from the MoBo serial header, then connecting to a distrubution block then the amps connecting to that. I have a total of 4 amps, and I think this may be the issue. In that case, can I simply add a relay that has a 12v signal and the serial port simply triggers the relay, which all 4 amps will be connected to?
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [100%]
BUG WORKOUT [75%]
INTERIOR MODS [50%]
BUDGET [380%]
HiJackZX1 Work Log
HiJackZX1 is offline   Reply With Quote
Old 06-24-2008, 06:37 PM   #19
My Photos: (0)
I don't think the serial port puts out enough current to activate the coil in the relay. Best bet would be to have a transistor being switched on by the DTR line and have that running the relay. A solid state relay would probably eliminate having to use a transistor as they're made to use low currents to turn on, they're usually more expensive though.
Old 06-25-2008, 03:09 PM   #20
HiJackZX1's Avatar
My Photos: (254)
I think ill go that route and use a solid state relay....
PLANNING [100%]
CAR PC ITEMS [100%]
BUG WORKOUT [75%]
INTERIOR MODS [50%]
BUDGET [380%]
HiJackZX1 Work Log
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
FAQ: RELAYS; how they work and how to wire it up... FusionFanatic The FAQ Emporium 8 06-25-2008 10:08 PM
StreetDeck Functions god_of_cpu DigitalMods (Scripts / API) 22 01-15-2008 10:44 PM
AMP 1.X Phidget Plugin Interface bcohen5055 AMP 68 09-06-2007 12:10 AM
Lock-start-puter circuit. KyleYankan Hardware Development 17 07-17-2005 12:05 PM
Will someone help me program my relay control module cproaudio Software & Software Development 6 09-04-2002 04:50 AM
Sponsored Links
Ad Management by RedTyger
