Quote: Originally Posted by
Rob Withey
The current has more to do with the size of the wire than the voltage.
I think I agree, I just started noticing that when I turn on the PC with AMPCTRL it takes almost a minute for the amps to come on, and when it does it fades in as though the amps are fighting for the wire to send the signal to power them on. On my setup I have a thin wire coming from the MoBo serial header, then connecting to a distrubution block then the amps connecting to that. I have a total of 4 amps, and I think this may be the issue. In that case, can I simply add a relay that has a 12v signal and the serial port simply triggers the relay, which all 4 amps will be connected to?
