Hey All,
Not too much of an electronics guy, so sorry for the n00b question.
I have a simple rocker switch that has 3 connections on it labeled: 'power', 'load', 'ground' (that is all the info that came with it). I want to use this switch to turn on/off a second OBD-II port that I've installed in the car. I use this 2nd port 24/7 (stashed behind the glove box) and have a VAG cable hooked up to it so I can do data logging of the car whenever I please. As it turns out, I can't use the OEM OBD-II connector, if this VAG cable is powered up though (which is problematic when going for emissions, getting the car tuned by someone else, etc).
So, my thought is to introduce this switch into the wiring between the OEM and the 2nd OBD-II port. This port has just 3 wires running to it: +12v, signal, and ground (and works 100% correctly when nothing is plugged into the primary port).
Here's my question: what do I hook up where? My best guess:
- 'Power' = I cut the +12v wire I have running from the primary OBD-II port over to the 2nd port in half. The half that is coming from the primary port (i.e. the power source) is what I connect up to this 'Power' connector on the switch.
- 'Load' = the other half of the line from #1 above, i.e. the half of the +12v line that connects to the secondary port.
- 'Ground' = this is what I'm really not sure of. Do I need to connect this ground? There is a ground wire already running to the 2nd OBD-II port. Do I cut this and attach both ends to the 'ground' connection? Do I ground it somewhere else?
TIA,
Per
BTW - it's a generic radio shack 12v rocker switch.
