Notices
Old 06-30-2008, 11:06 AM   #1
Started best thread ever
Brushless Motor
ok i have been looking around to find out how many mA it takes to power a brushless motor.
i have an 1/18 truck and i want to put a brushless motor in it.
anyone help
(and power the car by solar panels or something else)
but my car is small!
Ausi319 is offline   Reply With Quote
Old 06-30-2008, 12:40 PM   #2
I'm assuming you're talking about R/C cars? I think they take up quite a bit of power, plus you need the controller for the motor. I don't know the mA though. You should try looking up R/C brushless motors and seeing what typical amperages are.
kibble is offline   Reply With Quote
Old 06-30-2008, 01:26 PM   #3
yea i am i need to find out how many mA it takes. (it said around 7.2volts -12 volts will work)
I need to find out how many mA it takes
Old 06-30-2008, 01:29 PM   #4
Raw Wave
Tidder's Avatar
amps = watts/volts. Gotta have at least 2 of those to figure out the equation.
Ausi319, I find it very unbelievable that you'd continue to post on this website when in fact you're getting zero useful information from a bunch of sarcastic computer geeks. WTF are you doing man? Perhaps now would be a good time to go find an R/C forum. Otherwise, I'm jumping into the fun too.
Tidder is offline   Reply With Quote
Old 06-30-2008, 01:40 PM   #5
Curiosity's Avatar
You'd get a lot more help on rcuniverse.com but brushless motors on 1/18th can use upwards of 25Ah burst. Don't even think about solar panels. Power it with a Li-Po pack (2S or 3S) and get a good Li-Po balance charger.
Current depends on how fast you want to go. What Kv are you putting in it and what size/type/volt battery?
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 06-30-2008, 01:52 PM   #6
which would b better a 7200kv or a 6000kv?
Old 06-30-2008, 02:11 PM   #7
Curiosity's Avatar
Well, I have 11.1V x 8000Kv so it's 88,800 RPM max (well over 60 MPH). I'd say it's too much.
7200 x 7.2 would be 51,840 RPM. You have to also consider what's legal for different racing classes.
I'm starting to read another thread. Umh, maybe you should stay away from li-pos.
Old 06-30-2008, 02:18 PM   #8
k i was planning on running it with a 1500mA battery and broken solar cells scattered around the body to pick up sunlight and help recharge or if i have enough completly power it!
Old 06-30-2008, 04:09 PM   #9
Curiosity's Avatar
Uhm, yeah, good luck with that.
Unbroken ones might work better.
Something's broken...
Old 06-30-2008, 04:11 PM   #10
Fusion Brain Creator
2k1Toaster's Avatar
Ah man now here is another thread I have to subscribe too. This is just too much!
Old 06-30-2008, 04:12 PM   #11
Raw Wave
Tidder's Avatar
You're tellin me.
Old 06-30-2008, 04:13 PM   #12
2k1Toaster's Avatar
This might explain the theory better: http://www.mp3car.com/vbulletin/powe...ar-panels.html
Old 06-30-2008, 04:14 PM   #13
SD beats everything. So there.
danielkh's Avatar
To even bring the broken solar cells with him.......geeeeeeeez.......
Latest Install: http://www.mp3car.com/vbulletin/show...-part-3-a.html
My opinion is my own.
danielkh is offline   Reply With Quote
Old 06-30-2008, 04:21 PM   #14
Raw Wave
Rob Withey's Avatar
Be careful with brushless motors in an outside environment. The reason they put the brushes in is to brush all the muck out. Running a brushless motor in a dirty environment like RC cars run in will likely end up with a broken motor.
I'm going to hell
Systems retired due to new car
Rob Withey is offline   Reply With Quote
Old 06-30-2008, 04:45 PM   #15
I'm going to hell
I do hope you're joking.
Ausi, I kinda understand what you're trying to do, but I don't think a few solar cells scattered around the body of a tiny car will do much for you. I had a hard time trying to power a computer fan off of 12 4.5V solar cells I removed from those solar lights you set up outside in your yard that recharge themselves. I wired 3 in series and 4 sets of three of them in parallel so I'd get it up to about 12V and higher amperage. It still wasn't much and while it powered the fan enought to make it run, it didn't do too well on stuff that required more current. Plus you had to have it in almost full sunlight in order to make it even worthwhile.
Help: Building bike with electric scooter motor rockthevolvo Off Topic 1 06-10-2008 02:09 AM
motor backdrive deevee General Hardware Discussion 1 06-04-2008 06:16 AM
Motor circuit with reverse freestyler Hardware Development 21 08-25-2005 02:44 PM
Headlight motor to raise screen lostreception General Hardware Discussion 28 07-07-2005 05:46 PM
IGN controlled motor lostreception General Hardware Discussion 4 07-03-2005 12:25 PM
