Quote: Originally Posted by
kibble
I agree with Darque. I've taken apart some dell power supplies where the ATX connector was the same size and had all the same pins, but some of the voltages were located on different pins.
You may want to check your power supply and make sure that everything is the same. Newer Dells don't seem have the same thing going on. I've seen it more on older dells.
Exactly right.
I am NOT certain exactly when they changed, but Dell USED to switch a few (I think it was 2 or 4) of the wires around to force people to buy DELL replacement power supplies, which cost more.
Since they DID use a standard atx connector, that made it simple for the computer enthusiast niche to use regular power supplies as needed, but the average user was screwed.
Eventually Dell gave up and went with the standard.
I
think the change was about 4 years ago, but I am in no way certain.
The good news is that all of the voltages ARE standard, so either way you CAN use any power supply with any Dell- but make sure that the one you have matches the voltages in the m4-atx (or any other psu) before you plug things in.
The info on which wires and when the change happened is on overclockers.com (where I read it years back) and is sure to be elsewhere too.
