The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 07-03-2008, 01:20 PM   #1
My Photos: (0)
M4-ATX Help
i don't want to seem "spoonfed". and i did a search but couldn't find the answer i was looking for. so i will use as much detail as i possibly can so tell me where i went wrong.
I ran 8 guage wire with a 40 amp fuse for 9 feet from the positive end of the battery to the v+ line on the m4. I ran 8 guage onto a proper ground 2 feet away from the gnd terminal on the m4. (the m4 is not plugged in to anything)
using a circuit tester it will light up at random places across the board, but not from the 24 pin connector. or any thing near them.
i also ran an accessory line to the ignition terminal on the m4 atx, and nothing happened. what did i do wrong?
i saw other posts, and right now my main concern is just getting the computer to get power and boot up...ill worry about the 1 min shutdown problem later.
trover4 is offline   Reply With Quote
Sponsored Links
Old 07-03-2008, 01:54 PM   #2
My Photos: (0)
What MB you have.
soloxp is offline   Reply With Quote
Old 07-03-2008, 02:49 PM   #3
DJiK's CarPC Specs
DJiK's Avatar
Vehicle: 1995 Audi 90 Sport Quattro
My Photos: (0)
From what you have described you've done nothing wrong.
The modern computer PSU is made is such a way that it won't turn on unless it's attached to a motherboard (or hacked with a paperclip at the 20/24-pin ATX connector).
I suggest you to plug it in to a motherboard/computer and press the power button to see if it turns on.
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
DJiK is offline   Reply With Quote
Old 07-03-2008, 03:03 PM   #4
My Photos: (0)
my mother board is Intel D201GLY 1.33 GHz Celeron Mini ITX mobo
i figured it would send power throughout the m4 board without being plugged into a motherboard with the powerbutton on. but i just tried it and still nothing.
Old 07-03-2008, 05:12 PM   #5
My Photos: (0)
I have the Intel D201GLYA, Did you conect the 12v cable to the M4 and MB. Also did you connect pin 7-6 on jumper J8 then to the MB on/off. If that didn't work try a ATX PS and see if it boot.
Old 07-03-2008, 05:51 PM   #6
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (29)
You need the 4 pin cable from the M4 to the D201GLY in addition to the ATX cable. It's the yellow/black cable on the left in this photo.
Also, as suggested, did you connect the ACPI wire to the right pins on the M4 and mobo?
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 07-04-2008, 02:38 AM   #7
My Photos: (0)
yup im missing the yellow and black wire, anyone know where to get one?
Old 07-04-2008, 07:02 PM   #8
kibble's CarPC Specs
My Photos: (0)
One thing that doesn't seem touched upon yet is what mode you have the M4 set to with the dip switches? You will still need to have the 4 pin connector but it should still turn on without it. Like if it's mode P0 then you should at least have the 5VSB on at all times, (the purple wire). If that's not working then something else could be wrong.
kibble is offline   Reply With Quote
Old 07-07-2008, 02:07 PM   #9
My Photos: (0)
i found the 4 pin wire under my bed yesterday, but still nothing through it...i put the setting at p0 and i can't get a signal through the purple wire like you said kibble. im kind of dumbfounded, let me post some pictures so you guys can help me find what i did wrong.
the power line is showing it has power
the accessory line has power
even some random pin (that i have no idea what does) has power.
but alas, the purple wire has no power, (nor does any wire in the 4 pin or the 20 pin.)
Old 07-07-2008, 02:15 PM   #10
Raw Wave
Rob Withey's CarPC Specs
Rob Withey's Avatar
Vehicle: '97 Vauxhall Corsa 1.5 TD
My Photos: (0)
You don't have the power supply plugged into a motherboard, did you jumper PS_ON to turn on the power supply?
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Sponsored Links
Old 07-07-2008, 02:28 PM   #11
My Photos: (0)
i had already tried it, let me post a few snap shots, and see where i went wrong. (this is the first time in my life i hope i made a mistake).
this is how i have it hooked up
and i push the button, and nothing happens. any other ideas, or did i do something wrong here?
Old 07-07-2008, 02:31 PM   #12
My Photos: (0)
wait a minute, what do you mean by jumper ps_on?
Old 07-07-2008, 02:33 PM   #13
david69leonard's CarPC Specs
david69leonard's Avatar
Vehicle: 2003/mitsubishi/eclipse
My Photos: (13)
Is the fuse still good on the M4? I know its a dumb question, but everything looks good to me.
david69leonard is offline   Reply With Quote
Old 07-07-2008, 02:51 PM   #14
My Photos: (0)
yeah i just checked the fuse. not burnt and power going in one side and out the other.
Old 07-07-2008, 02:54 PM   #15
Raw Wave
Rob Withey's Avatar
My Photos: (0)
PS_ON is a pin on the ATX connector that is grounded by the motherboard to turn on the power supply. If the motherboard is not there then you can fool it into turning on by shorting PS_ON to ground. Otherwise the power supply will just sit there doing nothing. There is a section in the faq about it (in the section relating to using a conventional power supply to feed the car psu when running in the house).
Of course if you have a motherboard connected then this isn't a problem. It just looked as if you were expecting voltage to magically appear on the ATX lines without PS_ON being grounded.
BTW: test lights apply a slight load (more than a multimeter). If I were you I wouldn't go randomly testing voltages in a circuit on a "random pin (that i have no idea what does)". You might find a line that can't supply the required current, and break something.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Everything You need to know about your M4 ATX Fox_Mulder Power Supplies 26 08-25-2008 12:34 AM
Review: M4-ATX 250 Watt Intelligent Power Supply Bugbyte The Review Palace 8 08-11-2008 08:17 AM
question about m4 ATX tundra2000 Power Supplies 14 06-16-2008 11:44 PM
M4 ATX USB connection Arby Power Supplies 21 06-11-2008 12:25 PM
M4 ATX Turn On Problem Fox_Mulder Power Supplies 21 06-11-2008 08:32 AM
Sponsored Links
Ad Management by RedTyger
