Notices
Old 07-03-2008, 07:33 PM   #1
a little confused...
God evening all, just a quick hello from accross the pond where we drive from the correct, (hehe) sorry, RIGHT seat in the car. (and change gear with he trusty left hand too )
I have decided i want to have a go at a (budget) first attempt car pc...
i currently have lying round a spare desktop pc, which was a a p4 1.8 with 1gb of ram.... i assume i can pinch the mobo from this?
the first issue was that this pc is a dell, but having read the threads on here, i have just had the multimeter out, and am pleased to report it is wired to ATX standard.
What DC-DC PSU's can be used with this board (if any, im hoping there are!!).... the reason for me asking is, as this is a p4 board (i thinkt thats the reason anyway) aswell as the 20pin atx connector, it also has that extra four pin connector (yellow black yellow black) from the psu to the mother board... do any of the DC to DC power supplies support this?
thanks for your time guys.
Ste
Ste2 is offline   Reply With Quote
Old 07-04-2008, 12:54 AM   #2
I know the M2-ATX does. I'm sure there are others though.
blackcobra487 is offline   Reply With Quote
Old 07-04-2008, 01:05 AM   #3
Fusion Brain Creator
2k1Toaster's Avatar
Yes the M2 has this wire, as do the Opus line, and the DS-ATX.
The M2 will NOT power a desktop P4 well.
Old 07-04-2008, 01:08 AM   #4
Raw Wave
Tidder's Avatar
It seems to do OK on the older northwood and williamette based P4 processors. But I've only ever used a 400mhz fsb with the M2 psu. I ran a 1.8 for a little over a year, had a 2.4 in there for a while, then fried my mobo in an unrelated accident.
Tidder is offline   Reply With Quote
Old 07-04-2008, 01:09 AM   #5
galvitron's Avatar
The M2 may not have enough watts for your P4. You may want to look into a less hungry CPU. There are some very cheap options out there (smaller too)...
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 90%
Installation/Fab/Assembly (Revised v2):
[----------] 90%
galvitron is offline   Reply With Quote
Old 07-04-2008, 05:24 AM   #6
Its currently a socket 478 cpu which is a p4 @1.8ghz, what do you reccomend instead?
the current mains psu is only rated at 250w max.
What sort of whattage would i need do you think?
Thanks for the help so far.
Regards.
Ste
Old 07-04-2008, 06:19 AM   #7
galvitron's Avatar
The M2 atx and many power supplies are around 160W. You will need to factor in other components besides the CPU (monitor, USB devices, Motherboard, etc). Some P4s use over a hundred watts. By comparison, the new 45nm core 2 duos use 35w at peak.
Planning:
[----------] 100%
Purchasing:
[----------] 90%
[----------] 90%
Old 07-06-2008, 02:47 AM   #8
Raw Wave
Tidder's Avatar
A P4 1.8 should use at peak 75w.
im confused with power supplies now :( flavor4real Power Supplies 14 10-25-2006 12:38 PM
Should I change or Let her go?....So Confused BIzFlawless Off Topic 91 05-26-2006 10:27 PM
xenarc came today... confused chrislloyd LCD/Display 15 04-04-2005 09:01 PM
Audigy2 nx bass output confused rickyaswell Car Audio 8 10-08-2004 02:32 PM
Im confused... gsand Software & Software Development 2 10-07-2003 08:10 PM
