Notices
Old 07-10-2008, 07:07 AM   #1
Few questions on M4-ATX
I am going to use 8 gauge wire for the 12v and ground. Does the ACC wire have to be 8 gauge? Has anyone built a plug like adapter to disconnect easily? Did anyone put a fuse(s) inline? What size? I see the M4 has a 25 amp on it.
what type of enclosure is anyone using? I want to install in my dell and is there an easy way to install?
Sorry for all the questions but I am anxious to get things started.Thank U.
flyerman is offline   Reply With Quote
Old 07-10-2008, 08:43 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
No.
Yes.
Yes. Definitely put on on the constant 12v line. The debate is out whether it's needed on the ignition-controlled ACC line.
A 25A or 30A fuse WITHIN 18 INCHES OF tHE BATTERY would be sufficient.
Remember that the fuse is to protect the wiring, not hte equipment.
Do you really need an enclosure?
And you're going to have to get to fabricating. There's no easy means of installing.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 07-10-2008, 10:55 AM   #3
thank you for the quick and informative response.
Old 07-12-2008, 11:21 AM   #4
Yes.
Can you please elaborate?
Old 07-14-2008, 04:49 PM   #5
I don't have a quick disconnect, but I'm sure you could use anything that would accept an 8 gauge wire.
kibble is offline   Reply With Quote
Old 07-14-2008, 06:35 PM   #6
I just connected my wiring to the terminal posts: each connection is a possible failure point and can add resistance. I'm just a nOOb at this stuff, but I've been doing cars, bikes and computers (separately!) for years.
As for cases- I did put my psu in a project case from Radio Shack. Not a major process, and it does allow me to have a dedicated fan forcing airflow over the board while reducing the chance of something shorting out.
Of course, my whole computer is in... well, more than a single case.
rogerdugans is offline   Reply With Quote
Old 07-14-2008, 10:01 PM   #7
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Here is a picture of it inside a PSU enclosure.
Have you found the "everything you need to know about your M4" FAQ yet?
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Will someone be willing to answer a few questions about the Vietnam War for an essay? guitar333 Off Topic 6 05-25-2005 12:53 PM
Newbee Questions Ascension Newbie 1 04-03-2005 09:43 AM
ATX board power?? Alphared Power Supplies 9 01-10-2003 01:36 PM
Presario AT or ATX? ppgt94 Power Supplies 6 04-11-2002 05:45 AM
ATX and AT motherboard Beavis Power Supplies 1 05-10-2001 03:22 PM
