I currently have a PC that I built using the Voom case, also using the m2-atx...everything has been awesome with the past 2 years or so. The problem si that the motherboard I used is a bit weak for doing most common stuff. With the skin i am using (DFX) without the flash logo, sitting idle the cpu is about 75-80% and when playing music pretty much stays at 100%.
Anyways, I just came accross and bought an HP dc7800, this thing is perfect for a carPC and is quieter and smaller than my voompc setup...amazed. However it uses a power supply brick to power it. I'd like to not use an inverter , rather is it possible to hook this up to my m2-atx? or how would you suggest I wire this directly into my car's power. I did everything right from the start, the right gauge wires, dist blocks...etc. I run an Optima redtop. I really want to use this thing but want it wired in without having to use my inverter.
For what its worth, I dont mind cutting up the wire from the PC to the power supply brick to wire it directly into something, just not sure what.
Suggestions?
