Quote: Originally Posted by
ctx32
I plan to use this PS to power my Intel D945GCLF board.
I'm not sure if it more than I need, Becuase I won't have alot of Preps.
connected to the motherboard.
If it's more than you need for your project, then all the better. Better to have and not need than to need and not have.
Quote:
Also, My project has no ground except for the batteries.
The body is plastic.
Will this be a problem?
You shouldn't ground to the body, anyway. You should ground to the frame.
Even id this isn't possible for whatever reason (hi-tech carbon fiber frame, perhaps?), you can run the ground to the negative terminal of the battery.
