Hi All,
I need a technical help to clarify my installation.
I've got a Santa Fé 4WD 2.0CRDI with a 100Ah battery
Actually my Pc with M3-ATX is connected to the smoke Light plug and working (fine) only if i turn on the key or running my car.
Starting Sequence :
I need to wait the sparke plug warming up the fuel and after i can running the engine, but the PC is starting due to power on car.
In this case the autostart from M3-ATX is not efficient, why ?
Because the CRDI is a power hungry machine, and the motor ignition provoke a voltage shutdown (lights, clim and other are shutingdown during), results : the PC is down too.
To solve this problem: i'm starting the car and after , starting myself the PC by using a power switch connected on POWERSW connector of my motherboard.
I would like to connect my PC directly on the battery and use the S3 standby mode on PC (the goal is running it in less than 10sec
My questions are :
- When the ignition power, is my pc still power enough or the ignition will "pump" all power ?
- Is the standby mode will discharged my battery if i don't turn on the motor during few days?
- I've seen a KBD power on on motherboard , i presume i need to turn off this b
ecause it will "pump" for nothing ?
I've already got some part but i didn't know how to wiring all ?
1uF condenser, working fine but i don't know how to wire it in car.
Old battery (Spare solution because i don't know if it's working)
can we connect 2 batteries in 1 car without problem? and how?
