Notices
Old 09-10-2008, 10:52 PM   #1
modified ATX (current mode)
Hi!
The attached file is a modified schematic of ATX power supply which I want to use as current mode supply. So the output current from current sense transformer was used at Pin4 (Deadtime Control) of IC TL494, through variable resistor to adjust the desired current (9A). Please comment if this technique can deliver a constant current output. Voltage regulation is not necessary.
Regards
xyz9915 is offline   Reply With Quote
iGuidance Hacks pbarrette GPS 47 12-28-2007 04:06 PM
m1 atx is killing my battery on taxi mode cass944 Power Supplies 4 11-23-2005 10:54 AM
GPS / Map Point current position skippy76 RR Bug Tracker 1 10-10-2005 12:42 AM
Lilliput doesn't go into VGA mode anymore thefreeauction LCD/Display 10 09-23-2005 09:48 PM
