Old 09-11-2008, 06:35 AM   #1
hawkeyefile is an unknown quantity at this point
Battery backup for drained SLA's
I know the title sound odd but here is my idea; I started my car up from work and realized, "Crap, my battery's dead". I must have left my lights on. However after a buddy gave me a jump i went home and started working on a plan to remedy this problem (I live in a foggy area, and I tend to leave my lights on). My plan is simple, use four of these diodes (http://pdf1.alldatasheet.com/datashe.../datasheet.pdf)
put them in parallel so they can handle the current draw, then I use my silicon mats to mount them to the car chassis to dissipate heat. Next I'll make it so the current can only flow from the primary starter battery. After this I will use an 80 amp relay controlled by a switch in the cabin of my car. I am using an 8AH battery which is sufficient for my SUV (KIA Sportage 01). How this works is it keep my primary battery from draining by not allowing the current to pass through the diodes, unless the car has been started, and after the car has been started a relay is setup to go on and charge my battery off of the alternator. So the next time my battery is dead I flip a switch and start my car up as usual. Also the alt in my car is a 136amp 06 Dakota.
Sound good? Tell me what you think.
hawkeyefile is offline   Reply With Quote
Old 09-22-2008, 08:01 PM   #2
insaneramman's Avatar
insaneramman is an unknown quantity at this point
Cool Why Not...
A cheap and easier solution in my op. is this-
Buy two cheap 25 amp relays (wal-mart) wire your foglamps to come on with your car. Just seems simpler to me.
insaneramman is offline   Reply With Quote
Old 09-22-2008, 09:00 PM   #3
True, but this would also be nice if i drain my car from my power tools, or my audio.
Battery Loosing Charge TeamRSX Power Supplies 15 05-15-2008 11:26 AM
2nd battery + computer controlled lighting jparks27 Show off your project 22 06-02-2006 09:52 PM
FS on Ebay 12VDC 5.1Ah Ignition Backup Battery TheSpecialist Classified Archive 111 03-24-2005 09:32 PM
MPJA - MECI ASTEC DC-DC Converter Luc General Hardware Discussion 39 11-22-2004 10:31 PM
Backup Battery and power converter combo cadence117 General Hardware Discussion 3 10-11-2004 11:33 PM
