Old 02-07-2003, 06:02 PM   #1
rbarr110
Has anyone gotten a sproggy to work with EPIA boards?
I can't get my Sproggy 2.8+ to work with my 800mhx ITX board. This is the pre "M" version itx board.
If you have got it to work, how the hell did you do it?!?
rbarr110 is offline   Reply With Quote
Old 02-10-2003, 11:00 AM   #2
rbarr110
Angry
I take the lack of replies as a big fat NO.
Old 02-12-2003, 08:39 PM   #3
Ces///M3
i got my sproggy up to 600mhz with just a regular hard drive attached... I think anything more is pushing it beyond its limits
You can always try to use a laptop hd, that might work... I cant guarantee it though
Ces///M3 is offline   Reply With Quote
Old 02-12-2003, 10:36 PM   #4
Registered User
CrazyLittle's Avatar
CrazyLittle
I am powering a Via Epia 800, Lappy hard drive, and USB LCD from a sproggy.
You've got about 65-70W of power to work with. Don't go overboard, but don't think it's the end of the world. People were using the sproggy for quite a while with plenty of sucess.
HOWEVER - you'll find that it's much easier and cheaper to probably just daisy-chain two of the mini-ITX power supplies together (one for the mobo components, and one for your additional hardware).
And if you're still exceeding that kind of power, then screw it, go get a OPUS power supply.
CrazyLittle is offline   Reply With Quote
Old 02-13-2003, 12:02 AM   #5
rbarr110
All I am trying to run is the 800mhz ITX board, laptop CD-rom, laptop harddrive.
But the thing wont boot up at all. It boots fine with a regular PS.
When I manually ground pin 14 on the sproggy header it powers up and supplies the correct voltages. It just does not power up when connected to the ITX board.
ANy help here?
Old 02-14-2003, 02:46 AM   #6
Registered User
CrazyLittle
Are you using any PCI cards? Also are you certain that the RAM is seated properly. Check your connections and make sure the mobo and/or sproggy isn't grounding out. Try bootting a different motherboard with only video and ram (no other drives, etc) to see if it's a current problem.
Old 02-14-2003, 02:10 PM   #7
digitallexus
I have the M9000 and Sproggy 2.7.
To test a scenario with completely minimized power usage, I've tried powering up the motherboard with absolutely nothing attached. nothing. no memory, no keyboard, no harddrive, nothing. (even tried unplugging the processor fan). All on-board peripherals are disabled (i.e. lan, audio, etc)
With a desktop ac powersupply it starts up, POSTs and as expected complains loudly about missing memory, etc.
With the sproggy it just spins up the motherboard fan, but never POSTs. With a keyboard attached, you can see the keyboard flash as it gets initial power.
digitallexus is offline   Reply With Quote
Old 02-14-2003, 02:32 PM   #8
Registered User
CrazyLittle
EPIA M-series motherboards are already known to need more than 65w of power at startup. This has been posted repeatedly under threads entitled "EPIA M" and various other "OPUS AND EPIA" threads.
If it won't work with an OPUS, it won't work with a sproggy.
Old 02-14-2003, 11:55 PM   #9
digitallexus
Yes I have seen that statement before. The comments I saw were only speculation though and the person didn't really know for sure. Just saying it need > 65Watts is a little vague.
Now, if someone could prove that the 3.3v rail for instance requires X number of amps, but the opus and sproggy only supply < X, then we can attempt to fix the problem.
Supposedly OPUS made a simple? mod to the original version of their power supply to make it work. That seems to imply that it was something besides a redesign to increase in power output on a particular rail. ? No one seems to know what the mod is though.
In any case, it is likely a lack of power, but I would like to establish exactly on which rail(s).
For reference, I was able to make the M9000 work with a small (150w) AC atx power supply with the following specs:
3.3 7A
5 12A
12 5A
-12 300mA
I have a sproggy 2.7, which has the following specs: (approx 85watts)
3.3 5A (peak 6.5)
5 10A (peak 13)
12 1.3A
-12 100mA
Old 02-15-2003, 09:37 PM   #10
em00guy
3.3 7A
5 12A
12 5A
-12 300mA
3.3 5A (peak 6.5)
5 10A (peak 13)
12 1.3A
-12 100mA
does your m9000 work properly with the sproggy ?
em00guy is offline   Reply With Quote
Old 02-15-2003, 10:05 PM   #11
digitallexus
no I can't get the M9000 to work with the Sproggy 2.7. It powers up the processor fan, but never POST's.
The operation specs document on via's website show that the sproggy is powerful enough to run the motherboard once the machine is on. Unfortunately the document doesn't list the startup power requirements like they have done in guides for some of their other motherboards. maybe they don't want to make it public :-)
Here is the op guide:
http://www.viavpsd.com/product/3/4/EPIA M Operating Guidelines Version 1.10.pdf
As you can see below, the motherboard requires very little power ( only 26 Watts when doing the most intensive operation - playing a DVD ):
EPIA M 9000
Playing DVD
Test Voltage Real Voltage Tested Amp. Watts
+3.3V 3.37V 3.38A 11.3906W
+5V 4.89V 2.52A 12.3228W
5VSB 5.02V 0.14A 0.7028W
+12V 12.51V 0.164A 2.0516W
Total Watts: 26.4678W
Playing MP3
+3.3V 3.37V 2.98A 10.0426W
+5V 4.89V 2.05A 10.0245W
+12V 12.51V 0.162A 2.0266W
Total Watts: 22.7965W
Running Network Applications
+3.3V 3.37V 2.92A 9.8404W
+5V 4.89V 1.35A 6.6015W
+12V 12.51V 0.161A 2.0141W
Total Watts: 19.1588W
Idle
+3.3V 3.37V 2.73A 9.2001W
+5V 4.89V 0.98A 4.7922W
Total Watts: 16.7092W
Running Office Applications
+3.3V 3.37V 3.12A 10.5144W
+5V 4.89V 2.51A 12.2739W
+12V 12.51V 0.163A 2.0391W
Total Watts: 25.5302W
Old 02-15-2003, 10:21 PM   #12
mikeinsanmarcos
So, 2 amps is more a realistic draw on the 12 volt input right?
mikeinsanmarcos is offline   Reply With Quote
Old 02-15-2003, 10:27 PM   #13
digitallexus
by 12v input, do you mean the front side connection from the car battery to the sproggy?
I am not sure how to calculate the input amp requirements.
Old 02-16-2003, 05:41 AM   #14
PTCruiser's Avatar
PTCruiser is on a distinguished road
3.3 5A (peak 6.5)
5 10A (peak 13)
You don't have 10A on a the 5V line...(5A max 6.5A)
You have only one max for the +5V....
Are you using low ESR cap?
Put a bigger output ESR CAP on the 5V output (~1000 uf)
PTCruiser is offline   Reply With Quote
Old 02-17-2003, 05:07 AM   #15
digitallexus
No, actually I have version 2.7 of the sproggy. It has an extra 787 for twice the 5v power output. (2 * 5A = 10A and 2*6.5=13A peak)
