Old 02-11-2009, 01:03 PM   #1
Startingline13 can only hope to improve
How to connect laptop to Carnetix 2140?
I have my carnetix 2140 and my gateway p6a6 laptop with its PA-1650-01 power brick and I can't get it to be powered via the carnetix.
Well silly me, not understanding electricity right away I noticed the INPUT on the AC adapter is 100-240v ~ 1.5a but the OUTPUT is 18v-20v, 3.16A-3.42A
So now I have a carnetix which can only output 20V max on it's main line. I guess I have a few questions then.
1) Where would you find a laptop brick that could operate on just 20V (considering this one needs 100-240v and it's certainly not a beast of a machine)
2) Is my best bet at this point to look into an inverter instead, or a laptop/dc power supply?
Startingline13 is offline   Reply With Quote
Old 02-11-2009, 01:28 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
I'm not getting it. The laptop requires any voltage between 18v and 20v DC. The Carnetix outputs 20v. It's a match. You should be able to power the laptop from the 2140.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 02-11-2009, 01:49 PM   #3
That's what I initially though as well Bug.
Maybe i'm not getting something here though (and I'm not the greatest with electricity, so I wouldn't doubt it )
The power brick says it requires 100-240v of input, and outputs 18v-20v,
so shouldn't I need 100-240v from the carnetix to the power brick then?
Old 02-11-2009, 02:53 PM   #4
Alanh
If you want to use the brick and need 100-240v in, its probably AC. In that case you need an inverter to convert 12vdc directly from the battery to AC to supply the brick, skipping the Carnetix. The brick simply won't work from a low DC voltage.
Bugbyte is suggesting you leave the brick out and run the laptop directly from the Carnetix.
Alanh is offline   Reply With Quote
Old 02-11-2009, 03:01 PM   #5
Alan you can do that?
If so, how? That is what I planned on doing anyway (running the laptop from the carnetix, that is) If I can just skip the brick completely I'm all for it.
As it is, I have the detachable cord from the brick snipped where it would originally plug into a wall outlet. I have it split into Ground and + leads.
Old 02-12-2009, 09:35 AM   #6
How do I connect my laptop to Carnetix 2140?
I've been looking for quite a while now, on the forums as well as google on how to connect these two together. If possible, I am looking to skip using the power brick completely. Most importantly I am looking for a picture of some sort so I know exactly where to snip the laptop cable. Any help would be appreciated greatly.
Regards,
Dave
Old 02-12-2009, 11:15 AM   #7
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
Have you looked through the Carnetix forums yet?
http://www.carnetix.com/forum/
Machinehead is offline   Reply With Quote
Old 02-12-2009, 11:37 AM   #8
yes I have, but the manual as well as the forums aren't too descriptive. They both simply say something along the lines of "connect the primary 20v and primary ground to the laptop."
It is very vague as a number of people on the forums have pointed out. What part of the laptop cable? I have the detachable cable cut and the positive and negative leads exposed, but I can't get any power to laptop or power brick from the carnetix.
Do I need the power brick? The input is 100-250v (If I remember correctly off hand), where the input for the laptop itself is only 18.5-20v.
If I don't need the brick then what is its purpose?
Should I just snip the wire from the bring which plugs directly to the laptop, and use those power and ground leads to the carnetix?
Old 02-12-2009, 11:55 AM   #9
The power brick is where the conversion from AC to DC occurs. So, you won't need it in the car as the output from the Carnetix is DC. You need a wire that goes from bare leads (positive and negative) to whatever barrel connector your laptop needs. Make sure you set the output voltage on the Carnetix to whatever your laptop needs.
Old 02-12-2009, 12:07 PM   #10
Bugbyte's Avatar
Right, skip the brick. The Carnetix IS the brick. Connect the + from the Carnetix to the + of the laptop cable. This is the part that comes AFTER the brick and plugs into the laptop. Connect the grnd, or minus, from the Carnetix to the ground of the laptop cable.
If you aren't getting power out of the Carnetix, check the jumper settings. It can be tricky. Also, make certain that your are triggering the Carnetix properly. You need +, -, and you also need to connect + to the Carnetix's accessory wire. That is what signals it to turn on.
Want to:
-Where is the iBug?
Old 02-12-2009, 12:09 PM   #11
Bugbyte's Avatar
Threads merged as they are the same topic and OP. Don't double post.
Want to:
-Where is the iBug?
Old 02-12-2009, 12:13 PM   #12
It's just like our Mac Mini's, the only tricky part is the auto turn on and there are tutorials on how to do it on a laptop.
Old 02-12-2009, 01:34 PM   #13
Sorry Bug, I didn't mean to cross post like that, but I felt this title would get a better/more responses.
Also, thanks a lot for the response. As I suspected I can just skip the brick completely and use the cable straight from the laptop. Google combinations like "Carnetix to laptop" and visa versa and you'll see what i mean about not being able to find a clear photo/description of what to do.
My Carnetix is providing ample power as tested via the multimeter, so I'll try this out when I get home.
Old 02-12-2009, 03:29 PM   #14
Bugbyte's Avatar
http://www.carnetix.com/installation...anual_V1_2.pdf Look at page 14 in the manual. Connect the red to the + on the plug and the black to the grnd on the plug.
Note there are duplicate red and blacks. You can safely combine both wires together, then solder them to the laptop cable. Get some heat shrink tubing from Radio Shack and slip it over the wire before connecting the for a nice, professional look.
Here's a nice guide on how to splice wires.
If it is a barrel-type connector for the laptop, the outside is USUALLY for ground.
Edit - changed title of thread for OP.
Want to:
-Where is the iBug?
Old 02-13-2009, 12:16 AM   #15
It worked great! Thanks guys!
Power to Carnetix 2140, but no output?? Startingline13 Power Supplies 9 02-09-2009 11:38 PM
Carnetix P1900/P2140 and IBM T40 Laptop Power Question l00kster Laptops, Netbooks, Tablets, UMPCs, etc. 14 01-24-2008 02:55 PM
Laptop won't startup at ignition with carnetix hypnotiq Laptops, Netbooks, Tablets, UMPCs, etc. 12 04-09-2007 12:58 PM
How do I connect my carnetix to my aopen mini pc? ViViper1 Power Supplies 8 01-04-2007 01:29 PM
carnetix and laptop griz145389 Power Supplies 11 11-06-2006 11:51 AM
