Old 02-14-2009, 11:06 PM   #1
americasfuture2's Avatar
americasfuture2 is an unknown quantity at this point
p1900 problems ive never seen
so here lately, my p1900 has been acting funny. most of the time when i turn the ignition off, display and amp turn off but come right back on a second or two. and today, it never shut down. the only way i have solved this is by yanking the fuse to reset the p1900. it works like it should just once when i do that. im running version 2.2
anyone know what the problem could be? wires touching or grounding out that i should look for? jumper settings preferred or suggested that i should have set.
Gathering parts----99% (I'll always want something else, its never 100%)
Using and programming in RR 3.14% (I need tons of help on this one!)
First Actual 98 Blazer LT Install
First 08 Aveo5 SV Install
87 Fiero GT waiting
americasfuture2 is offline   Reply With Quote
Old 02-15-2009, 09:08 AM   #2
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
First things first, has it work correctly before and for how long?
Secondly, have you worked on or played with anything in your vehicle?
Assuming it has worked correctly for a period of time and you haven't touched anything, I'd recommend disconnecting the power wires to the P1900 for a few hours and then plugging it back them back in. That will reset the unit.
I've had a P1900 and a P2140 and they're very glitch to say the least.
Machinehead is offline   Reply With Quote
Old 02-15-2009, 12:50 PM   #3
yea its worked correctly like it should since the day i got it. ive had it for little over a year now. havent messed with anything in the car. no need to.
that must be it then, a glitch. ive unplegged the fuse a couple of times for a very very short time and it seemed to work after that. but just once. maybe ill leave it unplugged for a little bit longer this time.
87 Fiero GT waiting
Old 02-15-2009, 01:41 PM   #4
My P2140 decided last week that it would randomly shutdown the computer. I opened up my dash, checked all my connections, and today it doesn't even want to start. Pulled the plug for an hour, plugged it back in and it's fine. Drives me crazy.
P1900 not working?? makaufmann Power Supplies 2 10-11-2007 09:30 PM
ok with p1900? tomob_122 Power Supplies 1 09-10-2006 08:29 PM
P1900 problems InHoc General Hardware Discussion 6 08-11-2006 01:02 PM
Dell Inspiron 8200 & Lilliput TS problems? bkpsu LCD/Display 1 08-15-2004 02:55 PM
